| New Reply |
Calculating Tension in Overhead Conductor with added Wind pressure |
Share Thread | Thread Tools |
| Apr3-12, 11:50 PM | #1 |
Hi was wondering if anyone knows how to calculate the tension in a overhead conductor say 'Dog' conductor over a 100m Span with a wind of 900Pa given its properties are as below
'Dog' Conductor properties Diameter = 14.15mm Weight = 0.3965kg/m Area = 118.8mm^2 CBL = 32.7kN Expansion Co = 0.0000139 Mod of elasticity = 139 This is with an initial tension of 10% CBL. And no change in temperature. |
| Apr10-12, 08:44 PM | #2 |
If we take away the wind, I would presume that this is a basic catenary calculation; do you agree? What does the term "Dog" denote? What does a wind load in Pa mean? We normally specify wind loading by giving wind speed, so what is this? What is CBL? What are the units on your modulus of elasticity?
| Apr10-12, 10:41 PM | #3 |
Dog is the name of the type of conductor which is used. wind load is wind pressure which you can convert to from wind speed. CBL is calculated breaking load of the conductor and the units on the modulus of elasticity is GPa. Pa is pascals.
| New Reply |
| Thread Tools | |
Similar Threads for: Calculating Tension in Overhead Conductor with added Wind pressure
| Heat added to Monatomic Gas at Constant Pressure | Introductory Physics Homework | 6 | ||
| pressure in u-tube of mercury with added water | Introductory Physics Homework | 1 | ||
| Calculating wind pressure against a rigid wall | General Physics | 64 | ||
| how to calculate the tension of a overhead conductor | Mechanical Engineering | 0 | ||
