Register to reply
What is a nonconstant linear function?
by spoke
Tags: function, linear, nonconstant
Share this thread:
spoke
#1
Apr4-12, 11:11 AM
P: 5
arent linear functions always constant?
Phys.Org News Partner Science news on Phys.org
NASA team lays plans to observe new worlds
IHEP in China has ambitions for Higgs factory
Spinach could lead to alternative energy more powerful than Popeye
espen180
#2
Apr4-12, 11:21 AM
P: 836
No, they aren't. Concider for example f(x)=x.
Bacle2
#3
Apr4-12, 11:19 PM
Sci Advisor
P: 1,169
Actually, the only constant function that is linear is the 0 function.
If you have a linear map T:V-->W between V.Spaces (this generalizes to rings, etc.)
then, if T(v)==wo , i.e., T(v)=wo for all v in V, then:
T(v+v')=wo≠ T(v)+T(v')=wo+wo=2wo.
A similar argument applies to maps from a vector space to its base field.
spoke
#4
Apr5-12, 03:41 PM
P: 5
Quote Quote by espen180 View Post
well then i dont know what a constant and nonconstant linear functions are. Because f(x)=x is linear when graphed, so i was assuming linear is synonymous the word constant. as in a constant rate of change or constant slope.
Office_Shredder
#5
Apr5-12, 03:48 PM
Emeritus
Sci Advisor
PF Gold
P: 4,500
A constant function is a function which always takes the same value, for example f(x)=2.
All linear functions on Rncan be written as y=Ax where A is a matrix (in one dimension, just a number)
Bacle2
#6
Apr5-12, 04:05 PM
Sci Advisor
P: 1,169
spoke:
You may be confusing constant rate of change, i.e., constant derivative--a property of linear functions-- with constant function.
spoke
#7
Apr5-12, 10:45 PM
P: 5
Quote Quote by Office_Shredder View Post
So would this relation be an example constant function? {(1,2), (2,2), (3,2), (4,2)}
Bacle2
#8
Apr6-12, 12:37 AM
Sci Advisor
P: 1,169
Yes, exactly, that is what a constant function is like when seen as a subset of AxB.
Not to nitpick, but you may want to specify the sets A,B where you are defining
your function as a subset of AxB; here, A is clearly specified, but it is not clear
what B is (unless you assume your function is onto B).
Dickfore
#9
Apr6-12, 01:02 AM
P: 3,014
A linear function is constant if and only if its slope is zero. By contaposition, a linear function is not constant (i.e. non-constant) iff its slope is different from zero.
Bacle2
#10
Apr6-12, 01:56 AM
Sci Advisor
P: 1,169
Your right, Dickfore, but your example is that of a map from ℝ to itself may be too
specific for a general definition of function.
Dickfore
#11
Apr6-12, 09:46 AM
P: 3,014
Quote Quote by Bacle2 View Post
OK, make
[tex]
\mathbf{y}_{n \times 1} = \hat{A}_{n \times m} \cdot \mathbf{x}_{m \times 1} + \mathbf{b}_{n \times 1}
[/tex]
This is a general mapping from [itex]\mathbb{C}^m \rightarrow \mathbb{C}^n[/itex]. But, now, the function may be constant in a more general case, when [itex]\mathrm{rank}A \le m < n[/itex].
Register to reply
Related Discussions
System ODE, nonconstant but periodic coefficients Differential Equations 9
Exponential of nonconstant matrix Linear & Abstract Algebra 5
Dynamics Question using nonconstant acceleration Engineering, Comp Sci, & Technology Homework 4
Stopping distance with nonconstant deceleration Calculus & Beyond Homework 5
Friction and nonconstant acceleration? Introductory Physics Homework 1
