| New Reply |
Can Absolute Velocity be Measured? |
Share Thread | Thread Tools |
| May11-12, 10:30 AM | #69 |
Mentor
Can Absolute Velocity be Measured?I think that part of the problem here is the ambiguous use of the words exact and approximate. Austin0 should clarify. |
| May12-12, 05:09 AM | #70 |
When the tangent line is used to plot a point on a curved line in the neighbourhood of a given point, this point becomes an approximation because the tangent line is an approximation of the curvature in the vicinity of the given point.
The velocity at this point lies on the tangent, is not an approximation because we use the limit delta t tends to zero; in the domain of this limit, the infinitesimal displacement is almost an exact straight line(no room for curvature), hence the velocity is said to be exact. |
| May13-12, 03:47 AM | #71 |
Apparently I was again mistaken as you seem to be saying it is necessary to resort to other processes to define the line. Is this the case?? SO is the tangent line referred to here not a direct product of the derivative?? Is it not to be taken, as I did, as being exact?? So is the approximation that is mentioned here referring to the line itself or is it referring to the relationship of the line to points on the curve. It seems to me to clearly be the latter , am I wrong?? Thanks |
| May13-12, 03:58 AM | #72 |
Also I use the word ratio interchangebly with rate . I am beginning to suspect this may be semantically wrong in this context also? This statement was directed to the limits I was familiar with: asymptotic approach to c with constant acceleration, the "Slow clock transport" as velocity approaches 0, etc. When this was misinterpreted to apply to instantaneous velocity , tangents etc I immediately responded (below) that this was definitely not the case post 32 I was not completey wrong. Now I would say "like some limits and the Taylor series expansion" provide exceedingly useful and accurate approximations Just kidding. I plan to carefully avoid any such provocative statements in the future. Thanks |
| May13-12, 04:15 AM | #73 |
I hope you will bear with me if I state the obvious in an effort to clarify my meaning. Fundamentally all of mathematics is abstraction. But within that structure there are varying degrees of correspondence with the reality it is designed to describe. A velocity regarding an inertial particle has complete unqualified correspondence both as a description of the motion of that particle and as a predictor of future positions and times as long as it remains inertial. AN average velocity is essentially a complete abstraction. Equivalent to an average family having 2.73 children. A particle with an average velocity between two points may have never actually traveled any distance at all at that velocity. As a description or predictor it has almost no value regarding short intervals and only an approximate value over intervals equal or longer than the original AN instantaneous velocity regarding a particle under continuous acceleration is also an abstraction. The particle in question never actually travels any distance at all at that exact value. To say this value is an exact description of the motion of the particle is equivalent to saying an exact description of motion over no distance. A self contradictory description with no correspondence to the real world. The dimensionless mathematical point is itself somewhat problematic. It works fine for assigning coordinates to a position, because events are static by definition. But to attach a dynamic evaluation to such a point is a different story. A rate of change with respect to no duration is meaningless. As an abstract exact value as an input for other calculations [like calculting proper acceleration relative to ICMIFs, or input as u to v=u +at] it is not a problem because those functions use the exact value as a starting point , not as motion over an interval. But as a description of the motion of a particle, it is meaningless without an interval ,and as soon as you define any interval, (of time or space), the exact value no longer applies exactly to the motion through that interval. would you agree with this interpretation?? So my conclusion from all of the above is that an instantaneous velocity regarding an accelerating particle is exact as an abstract value but not as a meaningful description of the real world motion of that particle. But it is a meaningful and accurate approximate description of that motion over a very small interval. Hope this will clear up some of the confusion |
| May13-12, 06:32 AM | #74 |
Mentor
Btw, I was also misusing "exact". I said "exact" but what I meant was "well defined". The derivative is well defined, so we know exactly what it is. But the question is what things it is exactly or approximately equal to. Obviously anything is exactly equal to itself, so that is uninformative except as a definition. |
| May13-12, 07:06 AM | #75 |
1) Tenth molar solutions of Sodium Chloride and Copper Sulphate are mixed in the ratio 7 parts NaCl to 2 parts CuSO4. How much NaCl is left after the reaction has completed? 2) How would the rate of the above reaction change if the temperature were increased by 10°C? |
| May13-12, 12:43 PM | #76 |
Edit:Sorry, your statement is true if the velocity vector changes direction |
| May21-12, 12:48 AM | #77 |
I see what you are saying and that I was confused. But it appears to me that velocity as the derivative of position is merely a convention. That velocity as the derivative of time would produce the same slope and tangent. Correct?. So in practicallity the tangent is a linnear approximation of both position and time to the same degree of accuracy and it would seem to follow that the slope of the tangent would also have the same degree of approximate accuracy regarding the same small intervals around the point of exact values. Yes? Regarding the meaning of exact: Not approximate. Exact in the sense that it is accepted that the returns of most functions are exact values. Exact in principle, Ignoring possible round off considerations etc Exact as the return of v= u + at is taken to be an exact value. As far as I can see none of the usual definitions of exact are predicated on what the term is equal to. The specific value of that velocity is also exact as a description of the motion of an inertial particle but is not exact as a desription of the motion of an accelerating particle. In the first case it exactly describes the motion and exactly predicts real world measurements of position and time along the path. In the second case it does not describe the motion outside of a dimensionless point nor does it predict real world measurements of position and time on the path outside of approximate predictions within an extremely limited domain around that point. Hopefully we might find agreement on these definitions. Thanks |
| May21-12, 02:30 AM | #78 |
This is no different to saying that x(t)=vt+x0 is the exact location of a particle moving at constant speed v with initial location x0. Average velocity is an approximate value when averaged over a non-zero duration (unless the velocity is constant over the period of course). |
| May21-12, 06:11 AM | #79 |
Mentor
Oops, clearly the word abstract had come out in the conversation, but I still don't think it is a point of any confusion.
Nontheless, the definition of velocity is unambiguous and ubiquituous, there is no point in trying to change it. You will only confuse yourself and others trying to communicate with you. It is a very bad idea to even attempt it. The position and the velocity are mathematically orthogonal to each other. A point measurement of the velocity does not give any information about position, nor vice versa. Expecting that velocity tell you about position is like expecting stock tips from your thermometer. However, you are using the word "motion" which includes position, velocity, acceleration, and all higher order derivatives. Knowledge of the exact position at a point in time allows you to predict the motion at other times to 0th order accuracy. Knowledge of the exact position and velocity at a point in time allows you to predict the motion at other times to 1st order accuracy. Knowledge of the exact position, velocity, and acceleration at a point in time allows you to predict the motion at other times to 2nd order accuracy. ... |
| May23-12, 01:29 AM | #80 |
You seem to have some idea in mind that is different to standard meanings perhaps you could give an example? Would you disagree?? So perhaps the question could be ; Does a velocity regarding an accelerating particle , intrinsically provide the information needed to plot such a chart?? Regarding an inertial particle it clearly does. I hope you will take this question as it is explicitely stated You were countering arguments I never made. 2) And your counter argument had been repeatedly stated by me from the beginning. Velocity was exact as input for other calculations. But all those evaluations depend on using the exact abstract value within the mathematical structure not as a description outside of it and not as motion over time.. 3) Since you brought it up lets look at the question of the result in these cases Case ----elastic collision of a macro system. Supposing an accelerating system (rocket) collides with a cannonball. Would the resulting vectors be exactly the same as those consequent to the same interaction with the momentarily co-moving inertial system?? It seems to me they would not . That the propagation of momentum during collision would necessarily require some finite time interval during which the momentum propagating through the system from the thrust would have an effect. The magnitude of the effect would be dependent on the masses,velocity and magnitude of acceleration involved. Would you agree??. Case-----sub-atomic particle and rocket. Looking at the specific atom at impact; The momentum propagating away from thrust continues along that vector as long as it encounters additional mass. So at any instant the atom in question has arriving momentum to transmit to the particle, in addition to the momentum from velocity..As the particle has substantially less mass, the effect of that added momentum would have proportionately greater effect . Do you think this would not affect the resulting vector?? Case------inelastic collision I would think that the preceding would apply equally in this case, both to the resulting vectors and to the kinetic energy. DO you see any compelling reason to think there woud not be any effect??? Case------- Doppler shift Certainly under most circumstances it would seem that emission can be considered instantaneous. But what about high velocities and magnitudes of acceleration with long wavelength emissions?? Would you maintain that under all circumstances the measured Doppler shift would be exactly equal to the same signal from the MCIRF?? Any description of motion which says nothing about positions or times would seem to be, self evidently, an abstraction, not a description of the real world. Now if you are saying that a velocity regarding an accelerating particle should not be expected to directly describe it's motion in reality , I would not argue.. In the case in point , (constant acceleration) an expression of acceleration would be needed to explicitly and exactly describe that motion. If it was non-uniform acceleration under consideration, then it would be back to the same situation and an instantaneous acceleration evaluation would be an approximation and it would require some expression of jerk to exactly describe the motion and I would imagine with a limited range of exactness.. DO you disagree with the above??? What exactly is the meaning of 1st order accuracy???.. How does a position of itself form a basis for evaluating motion or predicting motion at other points? I am clearly missing something here. A last question; What is your interpretation of the unqualified expression (37meters/second)? What is it's intrinsic meaning?? Thanks |
| May23-12, 07:19 AM | #81 |
Mentor
Why do you not want to explain what you think velocity is an approximation to and what it is exactly equal to? To me, the hesitation to answer the question seems evasive. However, the answer is also "no" to the related question "Does a position regarding an accelerating particle , intrinsically provide the information needed to plot such a chart". If you are taking instantaneous positions and velocities then you need all higher order derivatives, as I said earlier. IMO, the distinction you are trying to draw between position and velocity is artificial, and is actually a distinction between point values and functions. If you have x(t) then you also know v(t). If you have v(t) then you also know x(t) minus some constant offset which has no physical significance. If you have only v(t0) then you don't have much information at all, and if you have only x(t0) then you have just as little information. Obviously, x(t) has more information than v(t0). Similarly, v(t) has more information than x(t0). That doesn't imply that either x(t0) or v(t0) are approximations. I clearly don't understand what you are saying and you don't intend to clarify, so I don't see the use of continuing. For completeness I will try to respond to your cases later in the day, although I think it is an exercise in futility and doubt that it will lead anywhere. I still don't understand what you think about velocity is approximate. |
| May23-12, 03:12 PM | #82 |
\frac{a(t)}{\left(1 - \frac {v(t)^2} {c^2} \right)^{3/2}} [/tex] |
| May23-12, 03:28 PM | #83 |
Mentor
You are, of course, correct. Thanks for the clarification. Also, now that you mention it, all coordinate systems whether inertial or non-inertial agree on the proper acceleration.
| May23-12, 05:06 PM | #84 |
| May23-12, 05:51 PM | #85 |
Mentor
I am not certain what you are asking, but I will do my best guess.
However, in both cases at each moment, the instantaneous momentum of each object is a function of the instantaneous velocity, and the total system momentum is conserved from moment to moment (in an inertial frame). The velocity is never an approximation to the value needed for the momentum, even for an accelerating rocket. |
| New Reply |
| Thread Tools | |
Similar Threads for: Can Absolute Velocity be Measured?
| Is velocity incremental when measured precisely? | General Physics | 5 | ||
| Absolute velocity measurements | Classical Physics | 3 | ||
| Angular velocity absolute? | General Physics | 1 | ||
| Can we measure absolute velocity? | Special & General Relativity | 10 | ||
