| New Reply |
Why the black hole density is called the infinite density. |
Share Thread | Thread Tools |
| Apr10-12, 09:39 PM | #52 |
| Apr10-12, 09:45 PM | #53 |
http://en.wikipedia.org/wiki/Shell_theorem The theorem basically says two things: (1) If you're on the outside of (i.e., above, further from the center than) a spherically symmetric mass distribution, you feel the gravity of the entire mass as if it were concentrated at the center of the sphere. (2) If you're on the inside of (i.e., below, closer to the center than) a spherically symmetric mass distribution, you feel *no* net gravity from it, because the contributions from all different parts of it cancel out. If you're in the interior of an idealized spherically symmetric body (like an ideal non-rotating spherical Earth), both (1) and (2) above apply. (2) applies to the part of the body that's above you, and says that that part contributes nothing to the gravity you feel. (1) applies to the part of the body that's below you, and says that you feel the gravity of that part normally, i.e., just as if the mass that's below you were concentrated at the center. As you descend through the body, more and more of its mass is above you (and so doesn't contribute to the gravity you feel), and less and less is below you. So the gravity you feel gets less and less, reaching zero just as you reach the center. |
| Apr10-12, 10:49 PM | #54 |
What is the difference between a solid spherical body and a uniformly distributed spherical particle cloud ,which of course can have a fairly dense distribution if we want??? |
| Apr10-12, 11:13 PM | #55 |
| Apr10-12, 11:14 PM | #56 |
In General Relativity, if we have a solid body in equilibrium such that there are stresses and pressures within the body, then its external gravitational effects will be different from a lower density particle cloud that is not in equilibrium even if it has the same total mass. The stresses and pressures add to the effective total mass of the solid body and the motion of the particles in the particle cloud will also have an effect. |
| Apr11-12, 12:29 AM | #57 |
Lets say we added mass to the Sun until it collapsed into a black hole and continued to add mass until it engulfed Mercury, Earth, Mars etc until only Pluto remained orbiting it. Would you agree that the black hole occupied a volume of space? Would you agree if occupies a volume then we can in some sense say it has a radius? Would you agree that to say it has no radius is to suggest that all points on the event horizon are at the same spatial point? Would you agree that the finite proper time taken by free falling observer to fall from the event horizon to the singularity contradicts the idea of their being volume or radius? Would you agree that no radius implies that the singularity and the event horizon are at the same spatial location? |
| Apr11-12, 08:38 AM | #58 |
I should note that there is a lot more lurking in the details of how "total mass" is calculated, as shown, for example, in this thread: http://physicsforums.com/showthread.php?t=585547 |
| New Reply |
| Thread Tools | |
Similar Threads for: Why the black hole density is called the infinite density.
| Density of a Black Hole | Special & General Relativity | 5 | ||
| Density of Black Hole? | General Astronomy | 1 | ||
| Density of a Black Hole? | General Physics | 2 | ||
| Black Hole: Infinite Density, Infinite Buoyancy? | General Astronomy | 7 | ||
