AP vs. CPAP: Which is Best for Sleep Apnea?
The discussion revolves around the nature of natural numbers, particularly in the context of proving that for any natural number n greater than 1, there exists a natural number k such that n-k=1. Participants explore definitions, axioms, and implications related to natural numbers, including the Peano axioms and set-theoretic definitions.
  • Some participants argue that since n is a natural number and n > 1, then n-1 must also be a natural number, suggesting k = n-1 leads to n-k = 1.
  • Others clarify that n-1 is indeed natural because it is an integer greater than zero.
  • A participant notes that proving the statement from the definitions of natural numbers can be surprisingly complex, highlighting two common definitions: the Peano axioms and the set-theoretic definition.
  • One participant elaborates on the Peano axioms, explaining the structure and properties of natural numbers, including the successor function and the induction axiom.
  • Another participant points out that the set-theoretic definition provides a unique set of natural numbers and allows for induction to be proven rather than assumed.
  • There is a question raised about how to prove induction from set-theoretic axioms, indicating interest in the relationship between these concepts.
  • A later reply questions the equivalence of the Principle of Induction to the well-ordering of natural numbers, seeking clarification on the axioms being referenced.
Participants express varying definitions and interpretations of natural numbers, with no consensus on the best approach to proving the original statement. The discussion remains unresolved regarding the implications of different definitions and the proof of induction.
Limitations include the dependence on definitions of natural numbers and the complexity of proving statements from foundational axioms. The discussion does not resolve the mathematical steps involved in these proofs.
Bipolarity
If 'n' is a natural number such that n>1, prove that there exists a natural number k such that n-k=1.
It raises the question: What is the definition of a natural number?
Could you say that because n is natural, n-1 must be natural so that if k = n-1, n-k = 1?
BiP
That seems like a good argument, just mention that n-1 > 0 since n > 1.
As for the definition of "natural number", they simply the positive integers. So, n-1 is natural because a)n is natural so n-1 is an integer and b)b>1 so n-1 >0
This is actually a surprisingly difficult question. Of course, it's very easy on the first glance. But if you want to work it out fully from the very definition of natural numbers, then it can be difficult.
There are two common definitions of natural numbers.
1) The Peano-axioms.
Natural numbers are a triple (N,s,0) with N a set,[itex]s:N\rightarrow N[/itex] a function (intuitively s(n)=n+1) and 0 an element of N such that
- there exists no x in N such that s(x)=0
- if s(x)=s(y) then x=y
- induction: if [itex]A\subseteq N[/itex] is a set such that [itex]0\in A[/itex] and such that if [itex]x\in A[/itex] than [itex]s(x)\in A[/itex], then A=N
From these axioms, you can reconstruct the theory of natural numbers. In particular you can prove the question in the OP. It is not that easy, however.
2) The set-theoretic definition.
We define
[itex]0=\emptyset[/itex]
[itex]1=\{0\}[/itex]
[itex]2=\{0,1\}[/itex]
[itex]3=\{0,1,2\}[/itex]
[itex]4=\{0,1,2,3\}[/itex]
and so on. (this needs to be made rigorous)
The set of all such sets is called the natural numbers. This satisfied the Peano-axioms with [itex]s(n)=n\cup \{n\}[/itex]. The advantage here is that there is a unique set of natural numbers. In the first approach, there could be many such sets (which are homeomorphic). Another advantage is that induction is no longer an axiom, but can be proven from the set theoretic axioms. This might be preferable as induction might not be so intuitive to be taken an axiom.
If you want a proof from basic definitions, that's a long proof!
One way to define the "natural numbers" is to use the Peano axioms:
The natural numbers consist of a set N, together with a function, s (called the "successor function") from N to N such that
1) There exist a unique member of N, called "1" such that s is a one-to-one function from N to N-{1}. (In other words, every natural number has a successor, every natural number except 1 is the successor of some natural number.)
2) If X is a set of natural numbers such that 1 is in X and, whenever n is in X so is s(n), then X is the set of all natural numbers. (This is the "induction axiom.)
We can define ">" by "m> n if and only if there exist a natural number x such that x+ n= m.
From there we can define "m+ n", for m and n natural numbers, by
1) 1+ n= s(n).
2) if [itex]m\ne 1[/itex], then there exist x such that m= s(x) and we define
m+ n= s(x+ n).
One needs to show that is "well defined". That is, that given any m,n in N, there exist a unique member of N equal to m+n.
Once we have that, we can define n- m as the unique number, x, such that m+ x= n.
Now, if n> 1, by definition of ">", there exist k such that k+1= n and therefore, n- k= 1.
(micromass got in ahead of me again!)
How can we prove induction from the set theoretic axioms? sounds very interesting.
What "set theoretic axioms"?? The Principle of Induction is equivalent, under the usual axioms of arithmetic, to the well (natural) ordering of the set of the natural numbers...is this what you meant?
DonAntonio
  • · Replies 17 ·
  • · Replies 16 ·
