Register to reply
How transformers actually operate
by sp00ky
Tags: transformers
Share this thread:
sp00ky
#1
Jan11-05, 05:29 PM
P: 22
I was just wondering how transformers actually operates. And I hear they need to use alternating current and I was just wondering why they need to do so.
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
The Bob
#2
Jan11-05, 05:37 PM
P: 1,116
Quote Quote by sp00ky
Transformers are large, ringed, pieces of metal that have two sets of coils around opposite sides. An AC current is used because this induces a magnetic field, that a DC does not. A different in the number of coils in the different sets means that the voltage changes from low to high or high to low (high and low not set values).
The Bob (2004 )
chroot
#3
Jan11-05, 05:48 PM
Emeritus
Sci Advisor
PF Gold
chroot's Avatar
P: 10,427
To clarify Bob's post a little:
Transformers require AC because passing AC through a coil creates a changing magnetic field around that coil. DC certainly does produce magnetic field, but it does not change with time.
When an AC current is passed through one of the transformer's two coils (usually called the primary winding), its changing magnetic field also engulfs the other coil (usually called the secondary winding). The electrons in the secondary winding react to the changing magnetic field by continuously moving. (If you applied a DC current instead, the electrons in the secondary winding would only move for a split second, then settle down -- you'd get no continuous current.)
In other words: a changing current in the primary winding induces a changing current in the secondary winding.
Transformers thus allow the movement of electrical energy from one wire to another, without the wires ever having to touch -- the energy moves from one wire to the other through the changing magnetic field. As The Bob says, the ratio of the number of turns on one coil to the other also determines the ratio of the potential differences (voltages) through the two coils.
- Warren
sp00ky
#4
Jan11-05, 05:50 PM
P: 22
okay...and is there only 2 types of transformers? A step up and a step down is basically the types of transformers there are right?
The Bob
#5
Jan11-05, 05:53 PM
P: 1,116
I can't see there being any others. You can step up the potential difference and step down the potential difference but what is the point in havong a transformer to keep the potential difference the same???
Chroot might say different and he will, therefore, be right but I think there can only be two.
The Bob (2004 )
sp00ky
#6
Jan11-05, 09:24 PM
P: 22
I know step-up transformers are used for tv's, pc monitors, and in many furnace-ignition circuits, but what types of stuff are used for step-down? I know some toys does but anythn' else?
vincentchan
#7
Jan11-05, 10:00 PM
P: 610
In order to minimize the energy loss, the transmition line from the power plant and you house operates at a very high voltage, Over 100kV is not uncommon.... but your power outlet is 110V only.... how do they do that? and why are they using A.C. (alternating current)?
Zaimeen
#8
Jan12-05, 09:36 AM
P: 40
Added to vincentchan notes, what component is integrated in your charger when you want to charge your mobile phone sp00ky?
Register to reply
Related Discussions
What voltage appears across the primary coil of this transormer Introductory Physics Homework 3
I want to know if there are many development on transformers. Introductory Physics Homework 2
Why is it that some transformers emit a hummin sound Advanced Physics Homework 3
Operate the auto transformer Electrical Engineering 3
Transformer engineering problem Introductory Physics Homework 3
