Why don't I weigh more at the poles
  • Context: Undergrad
  • Thread starter Thread starter notsureanymore
    Poles
The discussion revolves around the question of why a person does not weigh significantly more at the poles compared to the equator. It explores concepts related to gravity, centrifugal force due to Earth's rotation, and the effects of Earth's shape and bulge. The scope includes theoretical reasoning and some mathematical calculations related to gravitational forces and weight differences.
  • Some participants propose that the centrifugal force due to Earth's rotation makes individuals lighter at the equator compared to the poles, where this force is negligible.
  • Others provide calculations suggesting that a person weighing 70 kg would weigh approximately 0.2 kg less at the equator due to centrifugal effects.
  • Some argue that the gravitational potential at sea level is consistent everywhere, though gravity is slightly stronger at the poles due to being closer to the center of the Earth.
  • Participants discuss the equatorial bulge and its role in balancing gravitational forces, with some suggesting that the bulge is sufficient to counteract centrifugal forces.
  • There is a debate about whether the Earth will eventually flatten, with some asserting that the forces have reached equilibrium and no further flattening is expected.
  • One participant questions the relationship between gravity and Earth's rotational speed, suggesting that gravity is not caused by rotation but rather by mass distribution.
  • Another participant raises the idea that gravity may vary based on local mass distributions, such as over land versus ocean, and the effects of altitude.
  • Some participants express uncertainty about the nature of gravity and whether it is consistent at all points of equal radius from the Earth's center.
Participants express multiple competing views regarding the effects of centrifugal force, gravitational differences, and the implications of Earth's shape. The discussion remains unresolved with no clear consensus on several points, particularly regarding the nuances of gravitational effects and the role of Earth's rotation.
There are limitations in the discussion regarding assumptions about gravitational force, the effects of altitude, and the influence of local mass distributions. Some mathematical steps and definitions are not fully resolved, contributing to the ongoing debate.
notsureanymore
Hi all
Another thought I have been pondering is why don't I weigh significantly more at the poles than I do at the equator
The Earth rotates at n kilometers per hour, I think around ~1300 kmph
Would this not create a centrigual effect countering Earth's gravity. thus making me lighter at the equator than the poles where no real rotation is evident.
I know the Earth has an equatorial bulge. but to me. it seems to be a very small bulge, does this bulge increase the Earth's mass at the equator enough to counter the centrifugal forces.
I read elsewhere pole to pole the Earth is 22 km's less in diameter than at the equator. this seems marginal.
And.. will the Earth eventually flatten ?
Chris H.
good question... the Earth rotation speed is about
[tex]2 \pi R / T[/tex]
6 378100 m (radius of earth) * 2 pi / 1 day ( period of the Earth's rotation)
=2*3.14*6378100m/(60*60*24)sec
=464m/s at the equator
the centrifugal force is [tex]mv^2/R[/tex]
for a 70kg man, the force will be
70*464^2/6378100
=2.36N...
F=mg
m=F/g=2.36/9.8=0.2kg
so, at the equater.. your weight will be about 0.2 kg less than the weight at the pole
There were several similar discussions recently, the major point of which was that the gravitational potential at sea level is the same everywhere.
Ok the cetrifugal force is less than I anticipated. so the smallish bulge is enough to balance the gravitational forces.
This of course occurs at all points on the surface.
The upshot is that if the Earth was spherical and I wanted to lose weight I would move to the equator.
but as the Earth is suffering middle age spread I will have to go back to the gym.
Damn shame that .
Chris H.
Actually, the force of gravity is a little different at the pole. The pole is about 14 miles below sea level when compared to the Equator do to rotational velocity forcing the mass at the equator to bulge out. The difference is due to the altitude difference from the center of the Earth. Gravity changes with altitude.
This means there is more downward force at the poles.So, this must be added to the effect of rotational velocity.
"And.. will the Earth eventually flatten ?"
No. The two forces ('centrifugal' and gravitational) reach equilibrium at some point and the flattening does not continue.
I expect that happened during the formation of the planet. I don't know of any evidence to suggest that the bulging is changing in present day.
The gravity is different due to the altitude difference. You can't get away from that. More downward force is there due to the elevation.
The force of gravity is more at the poles both due to being closer to the center of the Earth and due to no centrifugal force. The use of 9.8 m/sec^2 is used as an approximation regardless of your latitude, or whether you're standing on Mt Everest or at sea level, because the difference is so small.
Btw, you wouldn't 'weigh' .2kg less at the poles because kg is a measure of mass, not weight. Regardless of how a particular scale uses or misuses units, you won't notice any difference on a balance scale since that's really measuring mass - you might notice a difference on a spring scale, if it's sensitive enough.
Correct. But, there is still a gravity difference because you are closer to the center of the Earth at the poles. No way around that.
notsureanymore said:
Hi all
Chris H.
hi, there,
i was just reading your message. are you suggesting that Earth's gravity has something to do with the Earth's rotational speed. if so, since we would not be attached by anything to Earth when it is stationary, wouldn't we be pushed away from Earth when it start's rotating? Newton's law of motion."we will continue moving on a straight line unless an external force acts upon us". If you suggest that this gravitaional force is created by our Earth's rotation, what force (external) is changing our course (from straight line to circular, along with the Earth's rotation?)
Cyp Mot
motswac said:
hi, there,
Cyp Mot
He wasn't saying gravity is caused by rotation, he was just saying that at the equator the centrifugal force would oppose the gravitational force, decreasing your weight slightly (assuming we define 'weight' in terms of the total force you feel, not solely in terms of the force due to gravity).
Ok this is interesting you are saying gravity is not a function of mass so much as a function of the centre of mass.
The following totally ignores other forces...
Wouldnt gravity be less at the poles due to less mass between you and the centre of the earth?
Wouldn't this also mean gravity is less at sea level over a deep portion of the ocean. than at the same level over land due to the fact that sea water is less dense than rock and magma?
What if you climbed a high mountain. Wouldnt gravity be more for the mountain climber than for the photographer hovering nearby in a helicopter. due to the large mass of the mountain below the mountaineer? (assuming the helicopter is not over the mountain)
OR
Is gravity the same at all points of equal radius from the centre of the Earth regardless of intervening mass?
The gravitational equipotentials are spherical shells centered on the center of the earth. The field increases outwards as a linear function of the radial distance from the center.
[tex]E = \frac {GM}{r^2} = \frac{G\rho}{r^2}~\cdot~ \frac {4}{3} \pi r^3 = Kr[/tex]
This expression holds from r=0 to r=R(poles). For R(poles) < r < R(local surface), you would expect the increase in the field to be less than linear, because the spherical shells are no longer completely filled with earth. Nevertheless, there must be an increase in the field.
But due to the centrifugal effect, the net field sees a reduction as described in an earlier post here.
The two effects should nearly cancel each other, making the surface of the Earth an equipotential.
EDIT : Googling, I've found that I'm wrong...but I can't see how. :frown:
In theory yes. But, in actuality no.
http://www.csr.utexas.edu/grace/gallery/animations/ggm01/
At the poles there is a fourteen mile difference in elevation than at the Equator. The amount of missing land mass at the pole does have an effect of the gravity. It is not enough to change or equal out the total difference.
OK Gokul was very close, I think.The most simple expression of Newtons law only accounts for point masses and for homogeneous spheres. Earth is not a homogeneous sphere by far. The most remarkable abaration is the equatorial bulge. This means that if you are at the equator, three things must be accounted for gravity correction.
First you're farther away of the centre oif the Earth this tends to decrease the gravitational force w/Newtons universal law. Next you're spinning, creating an apparent centrifugal force that is opposing gravity as well. But the excess mass is directly beneath you and this tends to increase gravity. The nett result is a very slight decrease.
At the poles the reverse is true. Closer to the centre, less R more gravity. No centrifugal force opposing gravity, but the excess mass is off to the sides instead of beneath you, that would decrease the gravitational force, compared to the sphere.
Therefore the gravity at sea level is not equal everywhere but there is a relation between gravity, and total pressure on the surface area, balancing the Earth.
But gravity is not the biggest anywhere on the surface of the Earth. So where would that be instead?
You would think so, but the only time the spherical shells model truly works for mass 'outside' your radius is if your mass really is a perfect sphere.
The perfect sphere model makes the real problem simpler. There is a certain amount of mass in front of you (towards the center of Earth) and a certain amount of mass behind you. Instead of calculating the amount of mass in front of you and the amount behind you, you can figure out how much mass way out on the opposite side is canceled by the mass behind you.
For non-spherical Earth, even though you're closer to the center of mass at the poles, all of the mass is still in front of you ... And you're closer to the mass on the opposite side of the sphere (and all the rest of the mass), as well.
Edit: Actually, not all of the mass is closer. Some of the mass near the equator is slightly further away. Your average distance from every point in the oblate sphere is closer and, more importantly, all of the mass is still 'in front' of you.
Seems to me if the Earth stopped rotating it would all equal out??
Eventually.
The Earth's rotation rate is slowing (ever so slightly), but the redistribution of mass to match the rotation rate is even slower. A lot of the motion of tectonic plates, etc is the Earth trying to redistribute its mass to match the current rotation rate.
So, yes, if the Earth stopped rotating, eventually the Earth would form a virtually perfect sphere.
The Earth isn't spherical, so integrating out the spherical shells won't give the right answer.
The Newtonian potential of the non-spherical Earth is used in the GPS calculations, for instance.
http://xxx.lanl.gov/abs/gr-qc/9508043 has an expression for it, which is their eq 2)
[tex] V = -(\frac{GM}{R})(1- \frac{J2}{2}(R/r)^2\,(3 cos^2(\theta)-1)))[/tex]
Theta here is the lattitude.
J2 is a commonly used measure of the Earth's departure from sphericity. It's definitinon is given in the NASA planetary data sheet
http://nssdc.gsfc.nasa.gov/planetary/factsheet/fact_notes.html
The origin of this expression may appear mysterious but it's not really, though it's a bit involved.
It's basically the result of a series expansion. There is an unfortunately not very legible derivation online
http://www.apl.ucl.ac.uk/lectures/3c37/3c37-6.html
Some keywords if you want to go Google-fishing "Gravitatioanl Potential Theory, Legendre polynomials"
Goldstein also derives the gravitatioanl potential for an approximately spherical body in "Classical mechanics", pg 226.
I think I wrote a little about this in a thread here somewhere before, but I can't find it :-(.
Slightly OT
I was wondering about the changing shape of the earth. as its rotational speed changes it needs to readjust its shape to maintain equilibruim.
Hence the plate shift that recently killed so many.
When a thought entered my cranium. the oceans act like a balancer. Now I am sure its only slight but without it wouldn't there be a risk of the Earth developing a wobble like an out of balance washing machine.
This could increase to the point of throwing us out of orbit (unlikely to ever get that severe of course), but without the oceans rebalancing the Earth everytime a major event occurs we would most likely be in a major p**.
now my thoughts wander to other planets without oceans. how do they cope? perhaps the atmosphere is dense enough to do the job?
Any thoughts?
(perhaps should this go to another thread.)
I think I started a thread about this a few days ago but they locked it for some reason. Why, I don't know. I think we were arguing to much or something. :bugeye:
Hang onto that thought, and realize that neither the moon nor Mercury have any atmosphere to speak of.
It is not clear to me that there is any way to disrupt the orbit of a planet by rearranging its mass.
The total energy of the system will remain constant. To change a planetary orbit requires that energy be added or removed from the system. A earthquake does not change the total energy.
Recall that the Earth's crust is pretty thin wrt to the radius of the Earth (roughly a few parts in a thousand), displacements of the crust, as in a major earthquake are on the order of a few meters, this is pretty insignificant on a planetary scale. It is said that the Indonesian earthquake caused a hitch in the rotation of the earth, note that this is rotation about the Earth's axis, NOT revolution about the sun.
Duh ! :rolleyes: I knew there was something funny about my dinner last night. I blame it all on spicy chicken ! :mad:
... I was wondering about the changing shape of the earth. as its rotational speed changes it needs to readjust its shape to maintain equilibruim. ...
Integral's correct. You can't throw a planet out of orbit by changing it's rotation about it's axis.
A risk? The Earth does wobble, thanks to torque from the Earth's axis being tilted relative to the Sun (about 23.4 degrees), thanks to the Earth's axis being tilted relative to the the Moon's orbit (the Moon's orbit has almost dropped into the same plane as the Earth's orbit around the Sun - it's only 5 degrees off or, it ranges from around 18 to 28 degrees relative to the Equator), and due to the other planets.
It's minor, but it is tracked by the International Earth Rotation Service ( http://www.iers.org/). They also track the Earth's rotation. You can peruse their bulletins to find out how fast the Earth was rotating a couple of months ago and how far the poles have moved (relative to celestial space). It takes them awhile to analyze the data considering the small magnitude of the variations their analyzing.
Check the Web site map. They have more Earth data than you ever imagined.
To really get a feel what they're doing with J2 and Legendre polynomials, check this site (http://www.floridageomatics.com/publications/gfl/toc.htm ), particularly the Appendix on spherical harmonics (http://www.floridageomatics.com/publications/gfl/spherical-harmonics.htm ). This is the best explanation I've seen on the internet and it's been copied, word for word, in many places. Unfortunately, the figures look worse and worse each time someone tries to copy them, so it's nice to read the original article.
This is really a sine regression where they created an equation to model the observed shape using Legendre polynomials.
Yes I realize the Earth does wobble. in a slow deliberate way thus we have seasons.
What I meant was that some event which causes the Earth to become imbalanced
although the chance of an imbalance being so large as to throw us out of orbit ever occurring is negligable. it was just a passing comment. We would be dead long long before that.
Any 'sudden' change in the Earth's rotation, even relativaly minor would be disastrous. (think of the winds) but again the mass of the Earth is such that it is extraordinarilly unlikely.
My original thought was of the oceans acting as a balancer. smoothing the rotation of the Earth so that minor imbalances could not occur.
As you know even a very minor imbalance can cause a tyre to shred or a washing machine to 'walk'. that's why modern washing machines have balancing mechanisms (usually a fluid ring) and car tryes are regularly checked and rebalanced.
I can make a correlation to the harmonic balance on a cars engine.It balances things out, also.
Anyways, the force is greater at the poles and an underwater pipeline run from the pole to the Equator would indeed flow to the equator. Even if there is friction and coriolis forces involved. Any bets as to what would happen?
We've discussed that before and it still wouldn't work.
Show me the mathmatical formula as to why it won't. Then I will believe you!
Actually, we have seasons because the Earth's axis is tilted relative to the Earth's orbit plane.
The oceans are a little more volatile than the surface. The Moon pulls them back and forth all the time. That's why folks on the coast have to keep track of tides. It also changes the Earth's moment of inertia constantly, which actually adds to the imbalance, not decreases it. Not only is there a second gravitational force acting on us, but our own mass tries to realign itself with the axis between the Moon and Earth.
Your idea about the tyre is a good point, but there's a little more to the tyre problem. If it were just rotating in free space instead trying to support and steer your car, it wouldn't shred. And if the floor weren't in the way, your washing machine would be perfectly happy rotating in an unbalanced manner.
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 41 ·
  • · Replies 40 ·
14K
