Cyrus
- 3,246
- 17
Hi,
I have a question on the method of calculation of the surface area of a surface. I am using "Calculus Concepts and contexts by stewart", chapter 12.6.
In it, he goes on to explain how to calculate the suface area of a surface as a double integral by using approximations. He breaks up the projection of the surface onto the x-y plane into a grid. And each grid maps out a grid onto the surface as well. Now he wants to find an approximate area of each of those squares, and sum them. A rieman sum basically. Now on the projection he lables each side of the square delta x, and delta y.
He then goes on to say that he needs to approximate each of those patches on the surface, and that can be done if you use two vectors that start at one corner of the patch and both end at each end of the patch. You can then do the cross product of these two vectors to find the area of one patch. Similarly, you can do this for all the patches and sum it.
Now, in order to approximate these vectors, he does the partial with respect to x, to find the tangent to approximate one side of the patch, and similarly with respect to y for the other side. These gives him two tangent vectors that lie on the tangen plane. And he crosses them to approximate the area of the patch.
Here come the confusion. When he calculates the area, he multiplies the tangent with respect to x, by delta x, and similarly for y, by delta y. Why does he multiply the tangents by these values?
Also, he WANTS the two vectors to approximate the sides of the patch, so that the area closely computes the area of the patch; however, the tangent vectors WRT x, and WRT y, can have different magnitudes depending on the original function that defines the surface. So what makes them work out so that the magnitude will ALWAYS give a good approximation for the area of the patch?
If the patch is very small, then the tangent vectors WRT x and y might be way too big. So when you cross them, you get a huge area relative to what the patch area SHOULD be. So what fixes this dilema?
Thanks for your help all,
Cyrus
Cyrus
