Replacement of Squaring in Variance Equation: Benefits?
The discussion centers on the variance equation and the comparison between the Mean Squared Deviation (MSD) and Mean Absolute Deviation (MAD). The MSD is favored due to its direct relationship with the Normal Distribution and its adherence to the variance law, Var(X+Y) = Var(X) + Var(Y), which the MAD does not follow. The conversation highlights the importance of understanding the different contexts in which these measures can be applied, specifically as parameters of probability distributions, statistics from samples, or formulas for estimating parameters.
  • Understanding of variance and standard deviation concepts
  • Familiarity with Normal Distribution properties
  • Knowledge of random variables and their characteristics
  • Basic statistics, including sample statistics and parameter estimation
  • Research the properties of the Normal Distribution and its significance in statistics
  • Learn about the law of variance and its implications for independent random variables
  • Explore the differences between Mean Squared Deviation and Mean Absolute Deviation
  • Study the applications of variance in statistical modeling and data analysis
Statisticians, data analysts, and students studying statistics who seek to deepen their understanding of variance and its applications in probability distributions.
vanmaiden
The variance equation basically sums up all the distances between each data value and the mean of the set. The interesting thing is that each distance and squared for a reason that I believe is to make the distance positive, but why don't the statisticians just take the absolute value of each distance to give a smaller number? Is there some benefit to having a large number to work with? I mean, the smaller numbers nevertheless have decimals that can be used to compare magnitude and such.
Thank you.
That's a good question and I don't think it has a simple answer. There are many reasons why the mean squared deviation is very useful. It is directly related to a parameter in the often used Normal Distribution, while the "Mean Absolute Deviation" (which is what you are proposing as an alternative) is not. If X and Y are independent random variables then variances obey the law Var(X+Y) = Var(X) + Var(Y), but I don't think the Mean Absolute Deviation obeys such a nice law.
The Mean Absolute Deviation has been studied and used, so you can't really say that statisiticans haven't tried it.
If you want to talk about things like the mean squared deviation or the mean absolute deviation, you need to be clear which of the 3 different meanings you are discussing. Each of these things can be 1) A parameter of a probability distribution, 2) a statistic computed from a sample or 3) a formula for estimating a parameter in a probability distribution by using values from a sample. Each of those 3 things can be discussed as 1) a random variable or 2) a specific value of random variable.
9K
