Converting Wind Pressure to km/h for Aluminium Openings | 2400 Pa Resistance
  • Thread starter Thread starter nicolasmarie
    Pressure Wind
The discussion revolves around converting wind pressure measured in Pascals (2400 Pa) into wind speed expressed in kilometers per hour (km/h), specifically in the context of aluminium openings that must withstand this pressure. The conversation includes the application of Bernoulli's equation and considerations regarding fluid density.
  • Nicolas seeks to convert a wind pressure of 2400 Pascals into km/h for aluminium openings.
  • One participant suggests using Bernoulli's equation under the assumption of ideal fluid behavior and perfect horizontal flow.
  • Nicolas calculates a wind speed of 60 m/s (or 216 km/h) using a density of 1.2923 kg/m³, questioning the accuracy of this value.
  • Nicolas mentions using an online converter that yields a different result of 60.945 m/s (or 219.4 km/h) and inquires about the reason for the discrepancy.
  • A later reply from Nicolas indicates that upon rechecking, there is no discrepancy, confirming the wind speed as 219.4 km/h with the same density value.
The discussion reflects some uncertainty regarding the conversion process and the use of density, but it appears that Nicolas ultimately reconciles the results from his calculations and the online converter, suggesting a resolution on that specific point. However, the broader question of the appropriate density value remains open to interpretation.
The discussion does not clarify whether the density value of 1.2923 kg/m³ is universally applicable in this context, nor does it address any potential assumptions in the application of Bernoulli's equation.
nicolasmarie
Hi,
I want to express a wind pressure of 2400 Pascals in terms of km/h (speed) ?
The context here is Aluminium Openings having to resist such pressure.
Thanks in advance,
Regards,
Nicolas.
u can use bernollis equation assuming it a ideal fluid and perfect horizontal flow
(pressure/density)=(((veocity)^2)/2)
Thank you for your reply.
I have a pressure of 2400 Pascal.
Reworking your formula from the standpoint of pressure and using a density of 1.2923 (kg/cu m), I am getting as answer: 60 for velocity. (I think it is 60 m/s or 216 km/h).
I have used an online converter called Cactus 2000 and got 60.945 m/s or 219.4 km/h.
Is there a reason for the discrepancy 216 km/h and 219.4 km/h?
Am I using the right density of 1.2923 kg/cm?
Thanks,
Regards,
Nicolas
I have just check the excel sheet anew, there is no discrepancy. The wind speed using equation and online converter is 219.4 km/h using a wind density of 1.2923 kg/cu m.
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 28 ·
