Solving for θ in a Parabolic Orbit
  • Thread starter Thread starter pelmel92
    Comet Orbit
The discussion focuses on solving for the angle θ when a comet in a parabolic orbit crosses the Earth's orbital path. The key equations involved are the energy equation E = 0 and the angular momentum equation l = mρ^2(dθ/dt). The participants clarify that the semi-latus rectum is given by 2p = Ro(1 + εcosθ), where ε equals 1 for a parabolic trajectory. Ultimately, the solution hinges on correctly applying these equations to isolate θ at the points of intersection with the Earth's orbit.
  • Understanding of orbital mechanics, specifically parabolic orbits.
  • Familiarity with the concepts of angular momentum and energy conservation.
  • Knowledge of the semi-latus rectum in orbital dynamics.
  • Basic calculus for manipulating differential equations.
  • Study the derivation of the semi-latus rectum in orbital mechanics.
  • Learn about the conservation of angular momentum in celestial mechanics.
  • Explore the implications of parabolic trajectories in astrodynamics.
  • Investigate the application of energy equations in orbital calculations.
Astronomy students, physicists, and anyone studying celestial mechanics or orbital dynamics will benefit from this discussion.
pelmel92
A comet of mass m moves in a parabolic orbit in the ecliptic plane (the plane of Earth’s
orbit), so its perihelion distance ρ (its closest distance to the Sun) is less than Ro (the orbital distance of the Earth around the Sun) and occurs when θ = 0 for the comet. (The comet will cross the orbit of the Earth twice- once moving inward and once moving outward.) In terms of p and Ro, find an expression for θ at the two times when the comet crosses the orbit of the Earth. Assume: m << Msun.
E = .5m(dr/dt)^2 + .5l^2/(μr^2) - GmM/r
where l is the angular momentum and μ is the reduced mass.
Alrighty, so far I know that m is nothing in comparison to Msun, so μ≈m. At perihelion ρ, θ is zero, and dr/dt=0, so the velocity there Vmax = ρ(dθ/dt), and l = mrvsin(π/2)= mρ^2(dθ/dt). Plus, this being a parabolic orbit, E = 0.
I've been trying to put that all together given that l is conserved and E remains zero at all distances:
E = 0 = .5m(dθ/dt)^2 - GmM/ρ = .5m(dr/dt)^2 +.5m[ρ(dθ/dt)/Ro]^2 - GmM/Ro
but I end up with a bunch of dr/dt and dθ/dt variables that I can't figure out how to eliminate... I just don't see how I can isolate and solve for θ at Ro. It seems like my whole approach is probably wrong. :/
Any help from you good folk would be MUCH appreciated.
EDIT: Whoops this was actually super simple. I'd just forgotten that the semi latus rectum = 2p= Ro(1+εcosθ), and that epsilon for the parabola ia 1.
Assuming that your edit is correct, what ends up being the solution? I am working on the same problem, and I am lost myself as well! Some guidance would be wonderful! Thanks.
  • · Replies 30 ·
