Thermodynamics question, heat transfer via radiation.
This discussion centers on the principles of heat transfer via radiation, specifically addressing a scenario involving two objects with differing surface areas and temperatures. An object with a surface area of 2 square meters radiates energy at a rate of 1 kW per square meter, while a second object with a surface area of 1 square meter receives 2 kW of power. The confusion arises from the expectation that the second object will radiate at a rate that exceeds the first, despite the fundamental principle that temperatures will trend toward equilibrium due to the temperature difference influencing radiation rates.
  • Understanding of Stefan-Boltzmann Law
  • Knowledge of thermal radiation principles
  • Familiarity with concepts of thermal equilibrium
  • Basic principles of optics related to mirrors and lenses
  • Study the Stefan-Boltzmann Law and its application in thermal radiation
  • Research thermal equilibrium and its implications in heat transfer
  • Explore the effects of surface area on radiation rates
  • Investigate the role of mirrors and lenses in focusing thermal radiation
Physicists, engineers, and students studying thermodynamics, particularly those interested in heat transfer mechanisms and thermal radiation principles.
mrspeedybob
Suppose I have an object with a surface area of 2 square meters at a temperature which causes it to radiate energy at a rate of 1 kw per square meter. It has a very large thermal mass and so for the purposes of this experiment, a constant temperature . Around this object I have a system of mirrors and lenses which focus all of this energy onto a second object with a surface area of 1 square meter. The mirror and lens apparatus also works in reverse so that all radiation emited by the 1 square meter object ends up striking the 2 square meter object.
I have 2 kw of power striking my 1 square meter object, so it should assume a temperature at which it will radiate 2 kw of power, but that would mean it is radiating 2 kw per square meter which would make it hotter then the first object. That can't be right because they should trend toward the same temperature.
I feel like it should be obvious, but I can't see how the temperatures trend toward equal.
Science news on Phys.org
It is the temperature difference between the objects that determines the radiation rate/direction.
  • · Replies 33 ·
  • · Replies 29 ·
