Induction Method for Proving 1² + 2² +...+n² = (1/6)n(n+1)(2n+1)
  • Thread starter Thread starter Benny
    Induction
The discussion revolves around the use of mathematical induction to prove the formula for the sum of the squares of the first n natural numbers, specifically the equation 1² + 2² + ... + n² = (1/6)n(n+1)(2n+1). Participants are exploring the necessary steps and clarity required in presenting the proof.
  • The original poster outlines their approach to proving the statement using induction, detailing the base case and the inductive step. They question whether their final expression sufficiently demonstrates the induction step. Other participants discuss the necessity of explicitly showing the replacement of n with (k + 1) in the final expression.
Participants are actively engaging with the original poster's method, providing feedback on the clarity and completeness of the proof steps. There is a focus on ensuring that the induction step is clearly articulated, with some participants emphasizing the importance of showing the equivalence of the formulas for n and (n + 1).
Some participants mention the need to verify the base case for n = 1 as part of the induction process, indicating a common understanding of the structure of induction proofs.
Benny
Hello, I am wondering how explicitly a result needs to be shown in induction questions.
For example prove that 1² + 2² +...+n² = (1/6)n(n+1)(2n+1) where n is a natural number. Here is what I did.
1. P(n) is the statement that the sum of the squares of the first n positive integers is (1/6)n(n+1)(2n+1). Show P(2) is true.
Edit: Fixed first sentence of the above paragraph.
2. Assume P(k) is true where k is a positive integer.
[tex] 1^2 + 2^2 + ... + k^2 = \frac{1}{6}k\left( {k + 1} \right)\left( {2k + 1} \right)[/tex]
3. Show that P(k+1) is true.
[tex] 1^2 + 2^2 + ... + k^2 + \left( {k + 1} \right)^2 = \frac{1}{6}k\left( {k + 1} \right)\left( {2k + 1} \right) + \left( {k + 1} \right)^2 [/tex]
[tex] = \left( {k + 1} \right)\left[ {\frac{1}{6}k\left( {2k + 1} \right) + \left( {k + 1} \right)} \right][/tex]
[tex] = \frac{1}{6}\left( {k + 1} \right)\left[ {k\left( {2k + 1} \right) + 6\left( {k + 1} \right)} \right][/tex]
[tex] = \frac{1}{6}\left( {k + 1} \right)\left[ {2k^2 + 7k + 6} \right][/tex]
[tex] = \frac{1}{6}\left( {k + 1} \right)\left( {k + 2} \right)\left( {2k + 3} \right)[/tex]
Is it fine up to the point above? Or do I need to also have the following?
[tex] = \frac{1}{6}\left( {k + 1} \right)\left( {\left( {k + 1} \right) + 1} \right)\left( {2\left( {k + 1} \right) + 1} \right)[/tex]
Any help appreciated.
your last step is absolutely nessisory (sry, don't know how to spell this word)... The reason is: you must show in the P(n+1) case, your formulas is the exactly the same as P(n) with n replaced by (n+1)...
first you must show it is true when n = 1
which is easy enough, 1 = (1/6)*1*2*3
then do n+1 as you did
I personally would write that last line you wrote to make it very clear that n was replaced with K+1
Cool, thanks for the help vincent and spectre.
  • · Replies 21 ·
