Why do resistors in parallel not follow the trend?
  • Thread starter Thread starter markm
    Resistors
The discussion revolves around the measurement of actual resistances of resistors in both series and parallel arrangements, specifically questioning why resistors in parallel do not conform to expected theoretical values. Participants are exploring the discrepancies between measured and theoretical resistances.
  • Participants discuss the methods of measuring resistance, including the use of a multimeter. Questions arise regarding the accuracy of measurements and the potential sources of error affecting the results, particularly in parallel configurations.
Some participants have provided insights into possible reasons for the observed discrepancies, such as the internal resistance of measuring instruments and energy loss in wires. There is an ongoing exploration of these factors without a clear consensus on the primary cause of the observed trends.
Participants note that the actual resistance readings are consistently lower than theoretical values, raising questions about measurement accuracy and the influence of experimental setup. There is mention of specific values and calculations, but no resolution is reached regarding the underlying reasons for the differences.
markm
hi. ^_^
we recently did this experiment on measuring the actual resistances of resistors. every time, the actual resistance was less than the resistance on the label, except for the resistors arranged in parallel.
the theoretical value for 100 ohm and 220 ohm resistors is 67.5 ohms, but our reading is 68 ohms. :confused:
in the series arrangement the value was supposed to be 320 ohms, but we got just 316 ohms. when we measured individual resistances, the measured value was also always less than the theoretical one.
does anyone know the explanation why the resistors in parallel don't follow the trend? thanks so much.. o:)
Just curious...how are you measuring the "actual" resistance anyway?
with a multimeter
Haha okay.
First off
[tex]R_{||} = \frac{(220)(100)}{320} = 68.75[/tex] on windoze calc...
And now it depends on your multimeter's predicted error interval. The 4 ohm difference seems quite large considering the low error in the parallel resistance measurement. Can you see why? (error wise)
Cheers
Vivek
The theoretical value should be 68.75 Ohms ! And that's the "calculated" value. So, your actual value is 68 Ohms, which is consistent with any real value!
You should expect your values to be less than the theoretical values because of various reasons: -
1. Energy loss due to resistance of wires in your apparatus. Wires heat up during the experiment due to there resistances and energy is dissipated form there
2. Internal resistance of your measuring instrument (multimeter)
3. Loose connections while setting up the apparatus. This lead to unaccurate readings obtained.
4. Your real measurement depends on the least count of the multimeter!
...so many reasons...
  • · Replies 34 ·
