New Reply
Solar Panel Debacle
Share Thread Thread Tools
Apr14-12, 09:59 AM   #1
Solar Panel Debacle
We are creating a solar device that locates the optimal position to gather sunlight, and then stores the light in an AGM battery that we have. We have a 6v battery and we ordered 4 6v solar cells. Unfortunately the 6v solar cells did not come in. There are 4v solar cells in one of the labs at school (2 cells 4.2V .18mA No load).
Assuming we wired them in parallel:
Could these be used to power the 6v battery up to 4v?
What would happen after the battery hit 4v?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Apr15-12, 06:24 PM   #2
Not much would happen. Your solar cell output is a million times smaller that a typical AGM battery capacity of 200 amp-hours. A quick calculation 200amp-hours/1.8ma = over a million hours of charge time with the cells in series. The battery has more internal leakage than that.
Apr19-12, 06:00 AM   #3
Recognitions:
Homework Helper Homework Help
Hi robotics1234!
Quote by robotics1234 View Post
How many amperes would you say the solar cells can deliver?
Hardly! But why not connect the photovoltaics series, then feed that nominal 8V to the battery. I think it should work. (You could add 2 diodes in series with the lead from the solar cells to drop around 1.5V if you wished, but I doubt that will be necessary.)
It will still be flat!
New Reply
Tags
solar power system
Thread Tools
Similar Threads for: Solar Panel Debacle
Thread Forum Replies
Solar declination / solar panel array design General Astronomy 2
solar boat having solar panel power problem General Engineering 13
6V 300mA solar panel or 4v 430mA panel Mechanical Engineering 5
45 W solar panel Engineering Systems & Design 1
