Benefits of ceramics in engineering?
The discussion revolves around the engineering benefits of ceramics compared to titanium and other materials. Participants explore the properties, applications, and limitations of ceramics in engineering contexts.
  • Some participants note that ceramics are hard and can withstand high temperatures, making them suitable for applications like cookware and space vehicles.
  • Others argue that while ceramics may be harder, titanium is generally stronger than most ceramics and highlight the brittleness of ceramics as a significant drawback.
  • It is mentioned that ceramics are more resistant to temperature and corrosion compared to many metals.
  • Some participants point out that ceramics are difficult to machine due to their brittleness, which poses engineering challenges.
  • One participant adds that ceramics can be produced in various colors, which can be important for aesthetic purposes in high-temperature applications.
  • Another point raised is that ceramics serve as excellent insulators with low thermal and electrical conductivity, contrasting with metals.
  • There is a mention of ceramics being used as coatings, potentially combining desirable properties from both ceramics and metals.
  • Ceramic magnets are highlighted for being non-conductive, lightweight, high energy, and inexpensive to manufacture.
Participants express differing views on the strength and brittleness of ceramics compared to titanium and other materials. There is no consensus on the overall superiority of ceramics or titanium, and the discussion remains unresolved regarding which material is more beneficial in specific engineering contexts.
Participants emphasize the distinction between hardness and strength, indicating that definitions and interpretations may vary. The discussion also reflects the complexity of material properties and their implications for engineering applications.
z-component
Hiya,
I've recently read about the material used for engineering, ceramics. What are the actual engineering benefits of using ceramics instead of titanium? Are there any other materials stronger than ceramics?
z-component
Well, they are two different things and not necessarily related. Ceramics are hard and can withstand high temperatures, so you generally use them when you are looking for those properties - ovens, cookware, dishes, space vehicles, etc.
Also, being hard isn't quite the same thing as being "strong." Titanium is stronger than most (all?) ceramics. Also, ceramics are usually quite brittle.
Ceramics benefit from being harder (be careful with using the word 'stronger'), than many metals. They are also generally more resistant to temperature and corrosion.
The drawbacks often relate to ceramics being much more brittle than metals. As a result, ceramics are very difficult to machine which is a major engineering drawback.
Ah, ok.
Thanks for the clarification. :smile:
Also, ceramics can be created in different colors where aesthetics at high temperatures are an issue. Such as in gas fireplace logs or decorative cookware.
Ceramics are also great insulators with very low conductivity (both heat and electrical). Metals are the opposite.
... and never forget use as coatings, sometimes can even get the best of both.
Ceramic magnets are non conductive, comparitively lightweight, high energy, and inexpensive to manufacture.
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 27 ·
9K
  • · Replies 17 ·
