Using Stokes' Theorem to Show F(r) is Conservative
  • Context: Graduate
  • Thread starter Thread starter wesleyad
    Stokes Theorem
Using Stokes' Theorem, it is established that a vector field F(r) is conservative if the curl of F, denoted as nabla X F, equals zero. Stokes' Theorem relates the line integral of F along a closed curve C to the surface integral of the curl of F over a surface S. Specifically, if ∮C F(r) · dr = ∬S (curl F) · dS and curl F = 0, then ∮C F(r) · dr = 0, confirming that the work done by F is independent of the path taken. Thus, F(r) is confirmed as a conservative vector field.
  • Understanding of Stokes' Theorem
  • Familiarity with vector calculus concepts, specifically curl and gradient
  • Knowledge of line integrals and surface integrals
  • Basic proficiency in mathematical notation and vector fields
  • Study the implications of Stokes' Theorem in vector calculus
  • Learn about the properties of conservative vector fields
  • Explore examples of calculating curl in different vector fields
  • Investigate the relationship between line integrals and path independence
Students and professionals in mathematics, physics, and engineering who are studying vector calculus, particularly those focusing on vector fields and their properties.
wesleyad
Hi I've got this question that I've been stuck on a while now.. I am sure its really obvious but i can't see to get it:
Q: with the help of stokes's theorem, show that F(r) is conservative provided that nabla X F = 0.
nabla X F is the same as curl F?
Cheers.
[itex]curl F[/itex] is sometimes written as [itex]rot F[/itex] or [itex]\nabla \times F[/itex]. It's the same thing.
You either have to show that [itex]\int F \cdot dr[/itex] is independent of path,
or that F(r) can be written as the gradient of a function. (Depending on your definition).
Hint: independence of path is the same is [itex]\oint F \cdot dr=0[/itex] for any closed path.
Hi there,
Yes, you are correct that nabla X F is the same as the curl of F. Stokes' Theorem states that for a vector field F and a surface S bounded by a curve C, the line integral of F along C is equal to the surface integral of the curl of F over S.
In other words, if we have a closed curve C bounding a surface S, then the line integral of F along C is equal to the surface integral of the curl of F over S. Mathematically, this can be written as:
Now, if we assume that nabla X F = 0, then this means that the curl of F is equal to zero. This implies that the surface integral of the curl of F over S is equal to zero. Therefore, using Stokes' Theorem, we can rewrite the equation as:
∮C F(r) · dr = 0
Since this holds for any closed curve C, we can conclude that the line integral of F along any closed curve is equal to zero. This is one of the conditions for a vector field to be conservative, as it means that the work done by the field is independent of the path taken. Therefore, we can say that F(r) is conservative.
I hope this helps clarify how you can use Stokes' Theorem to show that a vector field is conservative. Let me know if you have any other questions. Best of luck!
