| New Reply |
Newtonian relativity |
Share Thread | Thread Tools |
| Apr19-12, 10:51 AM | #18 |
Mentor
| Apr19-12, 10:53 AM | #19 |
| Apr19-12, 01:20 PM | #20 |
so i don't get either yours or Dale's critique of Newton's axiomatic insights of the day. they sure seem reasonable to me, but given them we would expect an absolute frame of reference for Maxwell's equations and we always seemed to put that in our own frames, as observers. eventually physicists started to think about testable consequences of that notion and hence the Michaelson-Morley experiment was conceived. even though Einstein must have known about M-M, he did not use it in his SR thought experiment. it was more of this insight that, if all constant-velocity observers have equal claim to being "at rest" (and they are at rest from the POV of their own frame-of-reference), then their laws of nature must be equal and they both should measure and observe c to be the same. that is sorta a logical consequence of Galilean relativity, but it's subtle, at least for the 17th century. he came to that insight without drawing explicitly on the negative result of M-M, but i imagine that he used that to reinforce his thinking. i wonder what Einstein would have done if there was some systemic mistake made in M-M and repeated experiments that caused them to conclude we were moving through the aether. he might have ignored it as non-sensical and proceeded with his development of SR. still, i don't see how Newton would have been expected to use any other axiom for time than he did, given the physical world he observed. and this lesson should apply to us today regarding SR and GR, QM, Standard Model, ΛCDM, etc. what we take now as axioms might be refuted by our descendants. for instance, the accelerating expansion of the universe surely left me slack-jawed in the 90s. i did not believe it at first, but unlike superluminal neutrinos (which i also didn't believe), the accelerated expansion of the universe is an observation that is standing the test of time and repeatability. |
| Apr19-12, 02:41 PM | #21 |
Mentor
| Apr19-12, 02:49 PM | #22 |
http://teacher.nsrl.rochester.edu/ph...AppendixE.html At first sight my opinion is consistent with that description of the scientific method; and it would be helpful if you can elaborate, consistent with that description, why you believe that Newton did something quite different. |
| Apr19-12, 03:10 PM | #23 |
| Apr19-12, 03:14 PM | #24 |
PS. thanks to this discussion I took Popper from the shelve, and I agree with Einstein's remark there, in agreement with Popper and against positivism: "theory cannot be fabricated out of the results of observation, but it can only be invented". |
| Apr19-12, 03:20 PM | #25 |
| Apr19-12, 04:00 PM | #26 |
Newton developed a theory that matched and correctly predicted all experimental results within the level experimental accuracy available at the time. I don't see what the problem is. Universal time is very testable. Take two synchronized clocks and put one on the top of the mountain and the other deep in the ocean and let them run for awhile then bring them back and compare. Using the types of clocks available at the time of Newton, you would find them to match and therefore time is universal. Absolute time is also observable. There is an absolute t = 0 and it is the Big Bang. We cannot observe before the Big Bang, therefore time before then has no meaning. Newton was right on both counts (within the experimental accuracy of his time), so he does not need to correct anything. His theory is still right at low speeds and in small gravitational fields. To insist a dead theorist correct his theory because of experimental data that is only available hundreds of years later is absurd.
| Apr19-12, 04:11 PM | #27 |
| Apr19-12, 04:19 PM | #28 |
| Apr19-12, 04:20 PM | #29 |
Thus, step 2: Formulation of an hypothesis to explain the phenomena. In physics, the hypothesis often takes the form of a causal mechanism or a mathematical relation. |
| Apr19-12, 04:25 PM | #30 |
You read Newton from the perspective of post-Newton models. Just read it again, and tell me what in his theory could be the basis for defining such items as "inertial frames" (and note that no such term appears in his theory). Interestingly, it seems that as recent as Einstein's first SR paper the term "inertial frame" wasn't in use, for there he defined the frames to which SR relates as those in which Newton's laws [supposedly] hold.
| Apr19-12, 05:22 PM | #31 |
Mentor
| Apr19-12, 05:42 PM | #32 |
Mentor
Assume only that which is necessary. That is an essential part of any activity [supposedly] grounded in logic. The danger in violating it is clear: if you throw in an irrelevant assumption, confirmation of your hypothesis' prediction will then erroneously appear to support that assumption. But fixing the problem is also simple: assume the opposite and see if the logic still works. If it does, then the assumption was unnecessary. |
| Apr19-12, 06:27 PM | #33 |
I'm aware that this is going off topic from the very meritable discussion on the scientific method, but it's one of my favorite points and relates to the initial question. [/ end off topic apology]
A really nice thing is to look at this whole exercise the other way around. Normally, you'd think of Galilean relativity as a consequence of Newton's laws - i.e. it only contains second derivatives wrt to time, so you can add any first or zero order constants of integration you like, given you apply them correctly. However, you can turn this argument beautifully on it's head - you can derive the classical action, and therefore all of classical mechanics, from assuming just assuming Galilean relativity. I would recommend reading Landau-Lifshitz Mechanics I to anyone who hasn't yet. Deriving Newton's laws in this way is pretty much the first thing done. Thus you can think of relativity as the axiom and mechanics as the consequence, rather than the other way around. |
| Apr19-12, 06:58 PM | #34 |
Mentor
![]() (source: http://www.flickr.com/photos/shishberg/2213562731/) Galilean relativity, right down to the ships.The motions of bodies included in a given space are the same among themselves, whether that space is at rest, or moves uniformly forwards in a right line without any circular motion. |
| New Reply |
| Thread Tools | |
Similar Threads for: Newtonian relativity
| Some questions on Special and Newtonian Relativity | Advanced Physics Homework | 1 | ||
| principle of newtonian relativity | Advanced Physics Homework | 1 | ||
| General Relativity vs Newtonian Mechanics | Special & General Relativity | 5 | ||
| Is general relativity incompatible with the Newtonian limit? | General Physics | 3 | ||
| Relativity vs Newtonian Physics | Special & General Relativity | 6 | ||
