Hey I was wondering why I got this problem wrong on magnetic fields
The discussion revolves around the motion of an electron and a proton in a uniform magnetic field, specifically focusing on their circular orbits and the direction of their travel based on their charges and masses. Participants are analyzing the implications of the right-hand rule in determining the correct direction of motion for each particle.
  • Participants explore the application of the right-hand rule to determine the direction of motion for both the electron and the proton. There is debate over the interpretation of the forces acting on each particle and how their charges affect their paths.
Some participants express confusion regarding the correct answer and the reasoning behind it. There is an ongoing examination of the right-hand rule and its application to the scenario, with multiple interpretations being discussed. A few participants assert that the proton should always travel counter-clockwise, while others question this conclusion.
Participants are working under the constraints of a homework assignment, which may limit the information they can reference or the methods they can use to arrive at a solution. The discussion includes attempts to clarify the roles of charge and mass in the motion of charged particles in a magnetic field.
chrissy2860
An electron and a proton each travel with equal speeds around circular orbits in the same uniform magnetic field ( I tried to attach a diagram...not sure if it worked but I've described it anyways). The field is into the page on the diagram. Because the electron is less massive than the proton and because the electron is negatively charged and the proton is positively charged:
a.)the electron travels clockwise around the smaller circle and the proton travels counter-clockwise around the larger circle.
b.)the electron travels counter-clockwise around the smaller circle and the proton travels clockwise around the larger circle.
c.)the electron travels clockwise around the larger circle and the proton travels counter-clockwise around the smaller circle.
d.)the electron travels counter-clockwise around the larger circle and the proton travels clockwise around the smaller circle.
e.) the electron travels counter-clockwise around the smaller circle and the proton travels counter-clockwise around the larger circle.
Right hand Rule
I answered b because if you use right hand rule then the electron and proton are both going clockwise but the electron is negative so it switches directions and so the electron is going counter-clockwise and the proton is clockwise. He said that the answer is a but I don't understand why since the electron should have made it switch directions. I tried talking to him about it but he just confused me more.
For now, only consider the proton. The force on the proton is directed towards the centre of the circle, so the right-hand rule gives clockwise or counter-clockwise for the proton.
I think this is incorrect. If the B field is into the page, the proton will always travel counter-clockwise, and the electron always clockwise. Try drawing it out. (a) is the correct answer.
chrissy2860: Look at it this way. If the proton velocity is initially up, the force (vxB, using the right hand rule) is to the left. This will cause the path to curve to the left, which bends the path in a counterclockwise direction. If the velocity is initially down, the force is to the right, which bends the path to the right, which is still in a counterclockwise direction. So the proton always circles counterclockwise. For the electron, everything is reversed, so it always circles clockwise.
Right hand Rule
Right hand rule will show that if the Field is into the page, the proton will circle in an anti-clockwise direction.
Remember, the proton is not trying to create the field, it is being influenced by an already existing field.
Fingers in the direction of the field, thumb in the direction the proton is moving, "out of the palm" gives the direction of the induced force - and the direction to the centre of the circlular path the proton will follow.
Oops, I meant to end my sentence with "?", not "." I was trying to get chrissy2860 to come with up counter-clockwise for the proton on her own, and thus lead her to (a), i.e., I meant to write
The force on the proton is directed towards the centre of the circle, so the right-hand rule gives clockwise or counter-clockwise for the proton?
