New Reply
Buckling and Deflection Analysis on ANSYS
Share Thread Thread Tools
Apr20-12, 04:42 PM   #1
I performed an analysis on a bike frame using ANSYS Workbench 13 and I got the following results (I was trying to calculate deflection/deformation)
- Set a mass of 80 kg on the bike and calculated the deflection which ANSYS (Static structural) provided as: 4mm
- Tried to validate using Castigliano's theorem which was: 6mm
*SO far this seems about right.
Then I went on to Perform a buckling analysis on ANSYS and it gave me a load multiplier of 1.99 which is roughly 159kg.
- I set the mass to 159kg on ANSYS (Linear Buckling) and it gave me a deflection of: 1.1mm
- Validated using hand calculations and it gave me a value of 1.5mm.
* Again this also seems right seeing as the answers converge.
Now the problem is that how do I get a lower deflection with a higher mass?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
New Reply
Tags
ansys, buckling, castigliano, deflection
Thread Tools
Similar Threads for: Buckling and Deflection Analysis on ANSYS
Thread Forum Replies
membrane deflection: theory vs ANSYS Engineering, Comp Sci, & Technology Homework 10
Ansys Apdl analysis Mechanical Engineering 5
ANSYS 2D Analysis Engineering Systems & Design 0
Help need for piezoelectric analysis using ansys Mechanical Engineering 5
Ansys coupled analysis General Engineering 3
