What are audio taper, linear taper, and reverse taper potentiometers?
  • Thread starter Thread starter yungman
The discussion centers around the definitions and characteristics of different types of potentiometer tapers, specifically audio taper, linear taper, and reverse taper. Participants explore the relationships between resistance and rotation in potentiometers, as well as the implications of these tapers in audio applications.
  • Alan seeks clarification on the definitions of audio taper, linear taper, and reverse taper potentiometers.
  • Bobbywhy suggests that Alan could find information on Wikipedia, implying that the topic is straightforward.
  • Alan questions whether reverse taper is synonymous with reverse audio (log) taper.
  • A participant explains that the taper of a potentiometer describes how variable resistance relates to pot rotation, with linear taper represented as a straight line and log taper as a logarithmic curve.
  • The same participant states that due to the physics of hearing, a logarithmic taper sounds linear in volume control applications, leading to the interchangeability of the terms audio taper and log taper.
  • The participant provides information on the designations of tapers in different regions, noting that the meanings of "A" and "B" differ between the USA and Europe.
  • Links to external resources are shared for further understanding of potentiometers and their tapers.
There is no consensus on the definitions and implications of the different potentiometer tapers, as participants present varying perspectives and seek clarification on specific terms.
Participants reference different designations for potentiometer tapers that vary by region, indicating potential confusion or misinterpretation based on geographical context.
yungman
I want to know what is audio taper, linear taper, reverse taper.
Thanks
Alan
Thanks
Is the reverse taper reverse audio(log) taper?
What does Pot Taper mean? Audio? Log? Linear?
The taper of a pot (potentiometer) is a description of how the amount of variable resistance relates to the rotation of the pot. This can be visually represented on a graph with resistance represented on the Y-axis and pot rotation represented on the X-axis. Some of the names of the tapers relate to how this relationship draws out on the graph. For example Linear taper is a straight line (linear) at 45 degrees up across graph. Log taper shows a logarithmic graph line. As it turns out, due to the physics of our hearing, a logarithmic taper actually sounds linear when used as a volume control. Therefore the Log taper is sometimes referred to as Audio taper since it's used extensively in audio volume control applications. You can see how these graphs look towards the bottom of the "Secret Life Of Pots" link below explaining more about pots.
Read this Secret Life Of Pots Article from the GEOFEX site to get a good understanding of pots and tapers.
Audio taper is the same thing as Log taper. The two terms are interchangable.
The taper of a pot is designated with a letter stamped onto the back (or side, or front) of most pots. WARNING: the "A" & "B" designations are not the same worldwide! The designations that I know of are these:
In USA
A - Audio or Log taper
B - Linear taper
C - Reverse Log taper
G - Graphic taper
In Europe
A - Linear taper
B - Audio or Log taper
G - Graphic taper
http://www.generalguitargadgets.com/faq/40-technical-questions/174-what-does-pot-taper-mean-audio-log-linear
And here at "Secret Life Of Pots" find the details with graphs: http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
Thanks Bobbywhy, this really help.
  • · Replies 30 ·
