Is There a Significant Shift in the Triple-Alpha Process?
  • Context: Graduate
  • Thread starter Thread starter Labguy
    Change Process
The discussion centers around the implications of a potential significant shift in the triple-alpha process, particularly in relation to stellar evolution models. Participants explore the sensitivity of this process to temperature and its effects on supernova models and solar models, as well as the reliability of the inputs used in these models.
  • Some participants note that the sensitivity of the triple-alpha process to temperature has been known for a long time, suggesting that solar and stellar models incorporate reaction cross-sections as inputs.
  • Others express skepticism about the claims made in popular press articles regarding the triple-alpha process, describing them as potentially containing "marketing fluff."
  • A participant speculates that changes in the reaction rate could significantly affect supernova models, particularly in red giants, while asserting that it does not impact main sequence stars.
  • There is a discussion about whether solar models use reaction cross-sections built in or run with a full range of experimentally determined values, with some participants questioning the robustness of these models without testing different inputs.
  • One participant emphasizes that the original post suggests a need to redefine the "full range" of values, which would necessitate changes in the models.
  • Another participant clarifies that a change in the triple-alpha process is unrelated to the solar neutrino problem, which was based on the Proton-Proton Chain process, indicating a distinction in the processes involved.
Participants express differing views on the implications of the triple-alpha process and the reliability of solar models, indicating that multiple competing perspectives remain without a clear consensus.
There are limitations regarding the assumptions made about the inputs to solar models and the definitions of the reaction cross-sections, which remain unresolved in the discussion.
Labguy
Just came across this, didn't see it posted elsewhere. Could be significant in our stellar evolution models. (?)
http://physicsweb.org/articles/news/9/1/8
Astronomy news on Phys.org
AFAIK, the great sensitivity of this process to temperature has been known for a long time. I would guess (and it is just a guess) that solar (and stellar) models are built with the reaction cross-sections as inputs, and that the models are run with at least the full range of values as determined experimentally.
Many PRs and popular press articles, IMHO, contain 'marketing fluff' (shall we say) - not enough to trigger a law suit under any 'truth in advertising' rule maybe, but ...
The sensitivity, yes. But, a change in reaction rate as described would and/or could still have a significant affect on supernova models / rates. It doesn't affect main sequence stars anyway, just cores over 100 million K; ie, red giants.
In all the papers I've read on solar models (one of which I've worked with directly) I've never seen this to be the case.
Which?
a) reaction cross-sections built in?
b) run with at least the full range of values as determined experimentally?
c) both the above?
d) something else?
IIRC, one strand of the work done during the decades' long investigation of the solar neutrino problem was to see how much variation in neutrino output (of the solar models) was possible, within the (extended) range of experimental cross sections.
From another perspective, without tests using different inputs, how can the robustness (among other things) of stellar models be (confidently) determined?
Nereid said:
Which?
c) both the above?
d) something else??
I would say "b" above is used often except that the values are determined mathematically rather than experimentally. But, the original post (link) seems to indicate that the "full range" has to be re-defined, so models would change also.
A change in the Triple-Alpha process would have nothing at all to do with the so-called solar neutrino problem. That "problem" (since solved) arose from calculations on the output of the Proton-Proton Chain process by which most H in our sun is converted into He. Triple-Alpha is not going on at all until He can fuse into C and O (mostly) above at least 100 million K and several billion years from now.
  • · Replies 30 ·
