Projectile lauched to the east of the earth has a reach R
  • Context: Undergrad
  • Thread starter Thread starter quasar987
    Earth Projectile
A projectile launched to the east of the Earth has a reach R, which is defined as the measure of the arc, specifically the length of the geodesic curve connecting the launch and impact points. The trajectory of the projectile is not parabolic; instead, it aligns with the geodesical curve on the Earth's surface. The discussion highlights the importance of using an ellipse-segment for long-range ballistic calculations to ensure accuracy in targeting, particularly with modern munitions.
  • Understanding of geodesic curves and their properties
  • Familiarity with projectile motion and trajectory analysis
  • Knowledge of ballistic trajectory calculations
  • Basic principles of physics related to motion on a spherical surface
  • Research the mathematical principles of geodesic curves on a sphere
  • Study the differences between parabolic and elliptical trajectories in ballistics
  • Learn about modern ballistic computation techniques
  • Explore the physics of long-range projectile motion and its implications
Physicists, aerospace engineers, military strategists, and anyone involved in the study or application of projectile motion and ballistic trajectories.
quasar987
I am told that a projectile lauched to the east of the Earth has a reach R. Is this the measure of the arc or of the chord joining the point of lauch and the point of fall ?
It's the measure of the arc,or if u prefer fancy words,the lengh of the geodesic curve pasing through the 2 points...
However,the projectile's trajectory is not parabolic,as i hope you know...The projection of this curve onto the surface of the Earth should match the geodesical curve.
Daniel.
Daniel.
Does it match exactly? I've heard that with the advent of truly long-range (long-range by modern standards) ballistic munitions, it became important to replace the classic image of the parabolic trajectory, and use the ellipse-segment to plot the firing solution, otherwise you miss the target. Does anyone know if that's true?
  • · Replies 60 ·
