Air Bubble Volume at Water Surface
The volume of an air bubble released at a depth of 40 meters in water, initially measuring 2.5 cm³, expands to 10 cm³ upon reaching the surface. This calculation is based on Boyle's Law, which states that the volume of a gas is inversely proportional to its pressure. The pressure at 40 meters, combined with atmospheric pressure equivalent to 10 meters of water, is essential for determining the final volume. The formula used is P1V1 = P2V2, where the initial conditions are set at depth and the final conditions are at the surface.
  • Understanding of Boyle's Law
  • Knowledge of pressure depth calculations
  • Basic algebra for solving equations
  • Familiarity with gas behavior under varying pressure conditions
  • Study Boyle's Law in detail, focusing on its applications in scuba diving.
  • Research pressure depth calculations in fluids, specifically for water.
  • Explore the relationship between temperature, pressure, and volume in gases.
  • Learn about the effects of atmospheric pressure on gas volumes at different depths.
Scuba divers, physics students, and anyone interested in understanding gas behavior under pressure will benefit from this discussion.
PRINCESS NOOR
Dear Sirs,
i need your help in this question, truthly i can't solve it. so kindly asking you to send me an answer with proper explanation if possible.
the question is:
an air bubble has a volume of 2.5 cm3 when released at a depth of 40m in water. What will its volume be when it reches the surface? Assume its temperature is constant, and the atmospheric pressure=10m of water
thank you
(This is elementary to a scuba diver.)
Google 'Boyle's Law'. It describes the very simple inverse relationship between volume and pressure in a gas.
Try this: (http://www.grc.nasa.gov/WWW/K-12/airplane/aboyle.html)
The only other thing you need to know is what the pressure at 40m is. Google 'pressure depth'
Try this:(http://www.americandivecenter.com/deep/preview/pd02.htm )
See what you can do with that, and if you get stuck, come back here.
Thank you for reaching out to us for assistance with your question. We are happy to provide you with an answer and explanation to help you understand the concept better.
In order to solve this question, we need to consider a few factors. First, we know that the volume of the air bubble at a depth of 40m is 2.5 cm3. This is because the pressure at that depth is higher than at the surface, causing the air inside the bubble to compress and occupy a smaller volume.
Now, as the bubble rises towards the surface, the pressure decreases. This means that the air inside the bubble will expand, causing its volume to increase. However, we also need to take into account the atmospheric pressure, which is equivalent to 10m of water. This means that the air bubble will only expand until it reaches a volume that is equal to the atmospheric pressure at the surface.
To calculate the volume of the air bubble at the surface, we can use Boyle's Law, which states that the volume of a gas is inversely proportional to its pressure. This means that as the pressure decreases, the volume increases. So, we can set up the following equation:
P1V1 = P2V2
Where P1 is the initial pressure (at a depth of 40m), V1 is the initial volume (2.5 cm3), P2 is the final pressure (at the surface, which is atmospheric pressure + 40m), and V2 is the final volume (what we are trying to find).
Plugging in the values, we get:
(40m + 10m)2.5 cm3 = 10mV2
100m cm3 = 10mV2
V2 = 100m cm3 / 10m
V2 = 10 cm3
Therefore, the volume of the air bubble at the surface will be 10 cm3. We hope this explanation helps you understand the concept better. If you have any further questions, please do not hesitate to reach out to us.
  • · Replies 25 ·
