What Happens to Free Electrons in a Single-Ended Wire?
  • Context: Undergrad
  • Thread starter Thread starter karen03grae
    Electrons Wire
The discussion revolves around the behavior of free electrons in a wire when only one end is connected to a positive terminal of a battery. Participants explore the implications of this setup on the nature of the wire, the movement of electrons, and the concept of equipotential surfaces. The conversation touches on theoretical and conceptual aspects of electrical circuits and electron behavior.
  • Some participants propose that free electrons in the wire do not get pulled into the positive terminal unless both terminals are connected, as a potential difference is required for current flow.
  • Others argue that while electrons may be attracted to the positive terminal, the effect is negligible compared to the number of valence electrons in the wire.
  • A later reply suggests that the wire and terminal become equipotential surfaces upon connection, meaning electrons do not flow significantly.
  • One participant clarifies that the free electrons in the wire are referred to as conduction electrons, distinct from valence electrons.
  • Another participant introduces the analogy of a capacitor, indicating that some charge may move to the terminal until equipotential is reached, but this movement is minimal compared to the total number of free electrons in the wire.
  • There is a mention of the role of potential difference and the necessity of a path for current flow, emphasizing that without both terminals connected, current cannot flow effectively.
  • One participant asserts that some electrons will indeed get pulled, but this will stop once the voltage matches the battery potential.
  • Another post contains a less formal explanation of how batteries work in relation to electron flow, though it lacks clarity and precision.
Participants express differing views on the behavior of electrons in the wire when only one end is connected to a battery. There is no consensus on the extent to which electrons are pulled into the positive terminal or the implications for the wire's properties.
Some statements rely on assumptions about the behavior of electrons and the definitions of terms like "valence" and "conduction" electrons. The discussion also highlights the complexity of potential differences and equipotential surfaces without resolving these nuances.
karen03grae
Q: When just one end of a wire is connected to a positive terminal of a battery, don't the free electrons in the wire get pulled into the positive terminal?
If these valence electrons did get pulled, what would this make the wire? Still a metal? No valences? Would the wire have a net "+" charge?
Reasoning: My book says when a wire is first connected (both leads), the free electrons at one end of the wire are attracted to the positive terminal, & at the same time, electrons leave the negative terminal of the battery and enter the wire at the other end. Continuous flow of e's.
Maybe since, in my question, there is no negative terminal connected, therefore no electrons being added to the wire, the free valences in the wire would rather 'just chill' and float around than be pulled into the positive terminal.
what do yall think?
No.
You need to have both terminals connected to induce an emf and make a current. And even then, the moving electrons will need to be replaced by more electrons, from the -ve terminal. I'm pretty sure the terminals aren't charged on their own, can someone confirm?
Even if the electrons were slightly attracted to the positive terminal, it would be negligible to the number of valence electrons.
The free electron model describes the metal as periodic +ve ions with many delocalised electrons.
Sure the electrons are delocalised, but the ionic lattice will not give up it's valence electrons so easily.
You'd have to get substantial positive charge to steal the electrons from metal.
No, electrons do not get pulled. Just imagine the wire as an extension of the terminal that it is connected to. The whole terminal-wire assembly is at the same potential. You must have a potential gradient (difference) to make electrons flow.
Okay. So they don't get pulled because as soon as the wire is connected to the + terminal, the wire and terminal are equipotential surfaces. So do the valence electrons float just keep floating around the copper atoms...
.CuCuCuCuCuCuCuCuCuCu. <--copper wire segment composition
.CuCuCuCuCuCuCuCuCuCu. . = electrons
That is supposed to be the copper atoms with their free electrons being shared. Sorry if this is leaning more toward chemistry than physics...but if anyone knows if this picture is correct then please let me know.
Yes, the free electrons float about the copper atoms "freely". Their motion is random, and so there is no net velocity in any particular direction.
But keep in mind that these free electrons are not valence electrons anymore. They are referred to as 'conduction electrons'.
I think this isn't quite right.
Say I have a copper wire and I plug it into a terminal. Then some charge moves from the wire to the terminal until the wire and terminal come into equipotential. Now, the number of electrons that move into the terminal will probably be quite small compared to the number of free electrons. So the wire still acts like a metal.
This is how a capacitor works.
But I guess this has nothing to do with the potential difference over the battery terminals, i.e. what makes the battery a battery, but only with the potential at this one terminal, which makes your point relevant not only to batteries.
What makes the electrons flow is 1) the potential difference over the two terminals, but this is not enough; 2) a path for them to flow and lower the potential difference. So obviously no current will flow if you just connect a wire at one terminal, except for the small flow of electrons to cancel the potential difference between end terminal and the copper wire.
Some will get pulled. As they do, the voltage will go up and meet the
battry potenetial and no more will get pulled.
This is called "charging a capacitor."
no negative not true
lets say we want to put batteres in a toy so it can work..ok
we take advantage of the loss of elctrons
wen the positive pole unleshes elctron its like energy for the toy
and after it out of energy it losses it powers and go to the negative poles
and if some one said or meend this then he is correct
  • · Replies 36 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 17 ·
