New Reply
Mathematica: Inertia Tensor w/ 3-d Rectangle
Share Thread Thread Tools
Apr25-12, 03:05 AM   #1
Hey All,
I'm trying to create a 3-D rectangle in Mathematica with the following measurements: Mass M=1.5 kg, and sides of length a=10 cm (parallel to the x-axis), 2a (parallel to the y-axis), and 3a (parallel to the z-axis). Let one corner be at the origin, and let the three adjacent edges lie along the coordinate axes, so the corners of the cube lie at (0,0,0), (a,0,0), (0,2a,0), (0,0,3a), (0,2a,3a), (a,0,3a), (a,2a,0), and (a,2a,3a).
I'm trying to set it up in matrix form, as I have to find the principal moments of inertia and principal axes as well. What's the best way to solve for this with the eigenvalues and eigenvectors of the tensor?
Also have to answer which of the principal axes would free rotation of the block be stable?
There's a long list of things I have to do with this problem, so I will update as necessary.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr25-12, 03:36 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hey Paul!
Quote by Paul E. View Post
If your three coordinate axes are parallel to the axes of symmetry (in this case, the sides of the box), then the moment of inertia tensor is diagonal
Apr25-12, 12:50 PM   #3
Thanks Tim,
Since I'm fairly new to Mathematica... all I've seen is ParametricPlot3d for other plots, but never seen anything for a block or the inertia tensor. Anyone familiar with the programming?
New Reply
Tags
angular velocity, inertia tensor, mathematica, moments of inertia, principal axes
Thread Tools
Similar Threads for: Mathematica: Inertia Tensor w/ 3-d Rectangle
Thread Forum Replies
Moment of Inertia of a rectangle? Introductory Physics Homework 9
Finding the dimensions of a rotated rectangle inside another rectangle. Precalculus Mathematics Homework 8
[SOLVED] Moment of inertia of a sign consisting of ring and rectangle Introductory Physics Homework 10
moment of inertia for thin uniform rectangle/hexagon Advanced Physics Homework 1
tensor product in Mathematica Math & Science Software 1
