Formula involving double integral over a disc?
The discussion centers on proving that for a uniformly continuous function \( g: \mathbb{R}^{2} \rightarrow [0,\infty) \) satisfying the condition \( \sup_{r> 0}\iint_{{x^{2}+y^{2}\leq r^{2}}}g(x,y)dxdy< \infty \), it follows that \( \lim_{|(x,y)| \to \infty}g(x,y)=0 \). The approach involves using polar coordinates and a contradiction method to establish that if \( g \) does not approach zero, it leads to a non-zero limit along some angle, contradicting the bounded integral condition. The discussion emphasizes the importance of uniform continuity in this context.
  • Understanding of double integrals in polar coordinates
  • Knowledge of uniform continuity in mathematical analysis
  • Familiarity with limits and asymptotic behavior of functions
  • Basic concepts of contradiction proofs in calculus
  • Study the properties of uniformly continuous functions in multivariable calculus
  • Learn about the application of polar coordinates in double integrals
  • Explore the implications of bounded integrals on function behavior at infinity
  • Investigate contradiction proofs and their role in mathematical analysis
Mathematicians, students of calculus, and anyone interested in advanced analysis of functions in multiple dimensions.
b.krom
Problem:
Can anyone help me out with the following problem:
I am given a uniformly continuous function : [itex]g:\mathbb{R}^{2}\rightarrow [0,\infty )[/itex] such that the following condition is satisfied:
[tex]\sup_{r> 0}\iint_{{x^{2}+y^{2}\leq r^{2}}}g(x,y)dxdy< \infty[/tex]
The question is to prove that:[tex]\lim_{| (x,y)| \to \infty}g(x,y)=0[/tex]
I tried to use polar coordinates instead of rectangular ones, but it didn't work out. Any help?
First, note that the limit intuiteively means that if you go really far from the origin, g becomes almost zero.
if you first suppose by contradiction the limit does not hold and [itex]g(x,y)=g(x(r,\theta),y(r,\theta))[/itex], then there must be some constant angle theta along which [itex]g_{\theta}(x(r),y(r))[/itex] has nonzero limit, right?
If you try to use polar coordinates, you get
[itex]\iint r g(x(r,\theta),y(r,\theta)), \theta\in[0,2\pi], r\in[0,\infty)[/itex]
Because g is always positive and uniformly continous, I expect this is larger than the integral over the radiant with theta such that there is a nonzero limit (admittedly, this needs to worked out a bit), which exists as assumed by contradiction. So then you just need something like [itex]\int_0^\infty f(x) dx < \infty, f(x)>0 \iff f(x)\rightarrow0[/itex], which is easier than what you had first.
Hope that helps a bit!
