Can Loophole-Free Bell Tests Resolve Quantum Nonlocality Debates?
  • Context: Graduate
  • Thread starter Thread starter Caroline Thompson
    Bell
The forum discussion centers on the feasibility and implications of "loophole-free" Bell tests proposed by R. García-Patrón Sánchez et al. and Hyunchul Nha and H. J. Carmichael, both published in 2004. These tests aim to resolve debates surrounding quantum nonlocality by utilizing homodyne detection and parametric down-conversion (PDC). The participants express skepticism about the experiments' outcomes, with a strong belief that classical theories will prevail over quantum mechanics. The discussion highlights the significance of phase relationships and Wigner densities in interpreting results, emphasizing the potential for a striking comparison between quantum and classical predictions.
  • Understanding of "loophole-free" Bell tests
  • Familiarity with homodyne detection techniques
  • Knowledge of parametric down-conversion (PDC) processes
  • Basic grasp of quantum mechanics and local realism theories
  • Research the implementation of homodyne detection in quantum experiments
  • Study the implications of phase relationships in quantum optics
  • Explore the differences between quantum and classical predictions in Bell tests
  • Investigate recent advancements in loophole-free Bell test experiments
Quantum physicists, experimentalists in quantum optics, and researchers interested in the foundations of quantum mechanics and local realism debates.
Caroline Thompson
Last year two very similar proposals were put forward for "loophole-free" Bell tests:
R. García-Patrón Sánchez, J. Fiurácek , N. J. Cerf , J. Wenger , R. Tualle-Brouri , and Ph. Grangier, “Proposal for a Loophole-Free Bell Test Using Homodyne Detection”, Phys. Rev. Lett. 93, 130409 (2004)
http://arxiv.org/abs/quant-ph/0403191
and
Hyunchul Nha and H. J. Carmichael, “Proposed Test of Quantum Nonlocality for Continuous Variables”, PRL 93, 020401 (2004), http://arxiv.org/abs/quant-ph/0406101
Does anyone know if either has yet been done, and if not why not?
These really do seem likely not to have any loopholes, and hence, as a convinced local realist, I am confident that the Bell inequalities used will not be violated.
They present an opportunity for showing a much more striking difference between the QM and local realist models than most other Bell tests. The QM argument relies on theory that says that when you subtract a "photon" from a beam you can create a "non-classical" beam. Additional theory says that when you use such a beam as one input of a homodyne detector and take the average over all possible phase differences, the distribution of voltage differences that you obtain has a dip around zero that can be used as an indicator of the above non-classicality. It leads to negative values of the Wigner density.
Following from this nonclassical nature of the beam, the QM argument is that this will lead to the usual prediction for coincidence curves, vis a cos^2 curve that violates Bell inequalities.
But the classical approach for the same setup comes to a totally different conclusion. It agrees that the subtraction of the "photon" has a significant effect on the results, but this is only because, by measuring this photon and restricting attention to cases in which it is recorded in coincidence with its twin, you are selecting the most interesting signals, the ones with the neatest phase relationships and strongest correlations between the two PDC outputs.
It is phase relationship, not Wigner density, that is the important variable, and the dip around zero is a natural consequence of the geometry of the sine curve, not an indicator of any strange quantum nature of the light.
The experiments as planned should thus provide a striking test of QM versus local realism. In the QM corner we have Wigner densities etc and the prediction of a cosine-squared curve that is a function of the difference in phase settings of the local oscillators. In the local realist corner we have classical theory, slightly augmented by some experimentally-inspired ideas about phase relationships in PDC processes, and the prediction of essentially a step function but one that depends on both local oscillator settings separately, not on their difference.
Incidentally, the same setup could very conveniently be adapted to illustrate the operation of the usual "detection loophole". It is absent in the proposals since the difference in output voltages always have some value, so that you always get, when you "digitise" it, either +1 or -1. There are no "non-detections". But you could instead look at the raw voltages ...
For my paper on the subject, see:
Caroline H Thompson, “Homodyne detection and parametric down-conversion: a classical approach applied to proposed “loophole-free” Bell tests”, http://freespace.virgin.net/ch.thompson1/Papers/Homodyne/Homodyne.htm, or, in two-column format, http://freespace.virgin.net/ch.thompson1/Papers/Homodyne/homodyne.pdf (January 2005)​
Caroline
Caroline​
I can't believe I'm doing this... :smile:
The corrected location of her paper is:
http://freespace.virgin.net/ch.thompson1/Papers/Homodyne/homodyne.htm
Now I do have one question, Caroline. Shouldn't you be laying the groundwork for dismissing this experiment? After all, what are you going to do once the experiment supports QM? :biggrin:
DrChinese said:
... what are you going to do once the experiment supports QM? :biggrin:
Thanks very much for correcting my link, and no, I don't need to worry! The experiment will not support QM! If it appeared to do so, I'd look for the reason, i.e. would study the experimental details to find new loopholes.
I'd be really interested to know whether or not they've now done the experiment. They have been very quiet, not responding to my direct question, which is strange in view of the facts that
(a) it was Grangier himself who drew my attention to the proposal, and
(b) they've already done the necessary preliminary experiments. See:
Jérôme Wenger, Rosa Tualle-Brouri and Philippe Grangier, “Non-gaussian statistics from individual pulses of squeezed light”, Phys. Rev. Lett 92, 153601 (2004), http://arXiv.org/abs/quant-ph/0402192
All that's left to do is a little more "coincidence" circuitry, most of which has been done before.
Caroline
  • · Replies 82 ·
12K
  • · Replies 58 ·
10K
  • · Replies 25 ·
  • · Replies 63 ·
9K
  • · Replies 37 ·
  • · Replies 75 ·
13K
