Magnetic Flux Calculation: Square Loop in 0.5T Field
  • Thread starter Thread starter domyy
The discussion focuses on calculating the magnetic flux through a square loop measuring 2cm x 2cm in a magnetic field of 0.5T. The correct formula applied is θ = BA, resulting in a magnetic flux of 2 x 10^-4 Tm². Participants emphasize the importance of consistent notation, recommending the use of capital 'T' for Teslas and noting that the equivalent unit of Webers (Wb) can also be used for magnetic flux.
  • Understanding of magnetic flux and its calculation
  • Familiarity with the formula θ = BA
  • Knowledge of unit conversions between Teslas and Webers
  • Basic geometry related to area calculations
  • Study the concept of magnetic flux in electromagnetic theory
  • Learn about unit conversions between Teslas and Webers
  • Explore applications of magnetic fields in physics
  • Investigate the effects of orientation on magnetic flux calculations
Students in physics, educators teaching electromagnetism, and anyone interested in understanding magnetic field interactions with conductive loops.
domyy
Can you check my solution?PLEASE:)
Calculate the magnetic flux through a square loop of 2cm x 2cm oriented perpendicular to a magnetic field of 0.5t.
θ = BA
θ = BA = (0.5t)(0.0004m^2) = 2 x 10^-4 Tm^2.
What do you guys think?
Thanks!:blushing:
θ = BA
Thanks!:blushing:
I think that you should use a capital T for Teslas consistently, particularly in the same equation :devil:
Otherwise it's fine.
Note that you might also use the equivalent unit of Webers (Wb) for the flux.
Wb = Tm2 = Vs
9K
