New Reply
rear disc brakes on 88 monte carlo racecar problems
Share Thread Thread Tools
Apr27-12, 01:16 AM   #1
Have a 88 monte carlo racecar, reciently installed a 9in ford with disc brakes using metric calipers, cant use aftermarket master cylinders or proportonal valve, an have a problem with no rear braking, tried a corvette master cyclinder but didnt seem to help, any ideas??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Apr27-12, 04:55 AM   #2
Recognitions:
Gold Membership Gold Member
the rules at the race track prohibit after market parts ..right?
Apr29-12, 03:08 PM   #3
yes we cant use aftermarket masters or proportion valves
Apr30-12, 01:36 AM   #4
Quote by cozmiccowboy View Post
... no rear braking, tried a corvette master cyclinder but didnt seem to help, any ideas??
"No braking", meaning the calipers aren't functioning, or the braking power is just very low?
Do you have (or can you borrow) a pressure gauge for the hydraulics?
May1-12, 05:34 AM   #5
Recognitions:
aside from the obvious, pinched brake line, frozen caliper piston...you need to find a master cylinder for the weight of your car, that uses four wheel disc brakes. I think you are using single piston calipers and the corvette may have dual pistons per caliper??
May4-12, 12:47 PM   #6
This car probably came with rear drums.
May13-12, 11:11 PM   #7
yes the car used to have drum brakes in rear and front disc , and yes the braking is very low or poor, all the calipers are single piston front calipers front and rear and are stock monte carlo, what master would you recomend that is not aftermarket or racing and must be a production part for street vechicles
May14-12, 03:19 AM   #8
Recognitions:
I would get on the phone and call Speedy Smiths guys..they have master cylinders for 27 Ford to a corvette..am sure the ygot one for you and cheap
http://www.speedwaymotors.com
New Reply
Thread Tools
Similar Threads for: rear disc brakes on 88 monte carlo racecar problems
Thread Forum Replies
Monte-Carlo simulation for a matrix model General Physics 1
Use of Monte Carlo Method to Solve Geometrical Problems in Radiation Transfer Programming & Comp Sci 2
Monte Carlo Sim Science Textbook Discussion 1
The difference between rear and front brakes of a bicycle Classical Physics 5
Monte Carlo and Inverse Monte Carlo - Good Sources for Self Study? General Physics 1
