| New Reply |
Finding the intergral function (dy/dt = a(q-y)) |
Share Thread | Thread Tools |
| Apr27-12, 01:28 AM | #1 |
I was working on an assignment and when I got my draft back, my teacher said I've made some errors working this out, however I'm not sure what I did wrong... Find the intergral function of: dy/dt=a(q-y) where t ≥0, y(0)=0 a and q are constants. 2. Relevant equations 3. The attempt at a solution [itex]\frac{dy}{dt}[/itex]=a(q-y) [itex]\frac{dy}{}[/itex]=a(q-y)dt [itex]\frac{dy}{(q-y)}[/itex]=adt [itex]\int\frac{dy}{(q-y)}[/itex]=[itex]\int adt[/itex] ln(q-y)=at+c q-y=eat+ec where: ec is a constant so let it = A q-y=Aeat -y=Aeat-q [itex]\frac{-y}{-1}[/itex]= -(Aeat) [itex]\frac{ (-q)}{-1}[/itex] y= -Aeat+ q ∴ y= -Aeat+ q Can anyone see any mistakes? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr27-12, 01:42 AM | #2 |
Hint: What is the derivative of ln[f(x)]? |
| Apr27-12, 01:46 AM | #3 |
I know the derivative of ln(x) to be
[itex]\frac{1}{x}[/itex] |
| Apr27-12, 02:33 AM | #4 |
The derivative of ln[f(x)] is f'(x)/f(x), where f'(x) is the derivative of f(x) with respect to x.
Substitute f(x) = x into this formula to convince yourself that the formula I wrote is a generalisation of the derivative of ln(x). Then try to work out the derivative of ln(q-y), where q is a constant. |
| Apr27-12, 02:35 AM | #5 |
wow... why must I divide the derivative function by the original function?
| Apr27-12, 02:51 AM | #6 |
You mean 'why must I divide the derivative function by the original function to obtain the derivative of ln[f(x)]?
I think you are asking why f'(x)/f(x) has to be the derivative of ln[f(x)]. This is a very theoretical question, and as such it is unlikely to come up in your tests. But just so you know, that formula can be obtained by considering the mother of all formulas you have ever studied in differentiation. It is this: [itex]\frac{dg}{dx} = \underbrace{lim}_{h \rightarrow 0} \frac{g(x+h) - g(x)}{(x+h) - (x)}[/itex], where [itex]\frac{dg}{dx}[/itex] is the derivative of a function g(x) with respect to x. This is the fundamental definition of the differentiation of a function and all other formulas that you have learnt can be obtained by using this mother of all formulas. For instance, to obtain the derivative of ln[f(x)], substitute g(x) = ln[f(x)] in that fundamental definition and work out the result. The result has to be f'(x)/f(x). On a more practical note, d/dx { ln[f(x)] } = f'(x)/f(x) means that d/dx { ln(x) } = ???? Try to work out the answer and then find d/dy { ln(q-y)}. |
| Apr27-12, 02:58 AM | #7 |
I've always had trouble deriving by first principles, could I use the chain rule?
let ln(q-y)=ln u? where u = (q-y) where q is constant then [itex]\frac{d}{dy}[/itex] = [itex]\frac{d}{du}[/itex] x [itex]\frac{du}{dy}[/itex] ? |
| Apr27-12, 03:08 AM | #8 |
Anyway, by the looks of your last post, you appear comfortable with the topic of differentiation, so try the chain rule. And you can check that you will get the same answer if you use d/dx { ln[f(x)] } = f'(x)/f(x). |
| Apr27-12, 03:18 AM | #9 |
so.
d/du = 1/u du/dy = -1? d/dy = 1/(q-y) x -1 d/dy = -1/q-y errr... this can't be right, can it? |
| Apr27-12, 03:34 AM | #10 |
| Apr27-12, 05:32 AM | #11 |
that would not be ln(q-y). it will be -
| Apr27-12, 05:49 AM | #12 |
Also the method that I used in my opening post... which I guess hasn't gotten me anywhere =D |
| Apr27-12, 05:52 AM | #13 |
[tex]\int \frac{1}{q-y}dy[/tex] Let [tex]u = q-y[/tex] Then [tex]\frac{du}{dy} = -1\rightarrow dy = -du[/tex] We then substitute using q-y = u and dy = -du [tex]\int \frac{1}{u} \left (-du \right )=-\int \frac{1}{u} du[/tex] Once you accomplish the integration, treating u just like you'd treat x, you replace any u in your answer with q-x. |
| Apr27-12, 06:08 AM | #14 |
| Apr27-12, 06:13 AM | #15 |
u = f(y) So it makes sense to differentiate with respect to y. You then get du/dy = f'(y). |
| Apr28-12, 05:19 AM | #16 |
Ok mate, you've lost me
[tex]\int \frac{1}{q-y}dy[/tex] Let [tex]u = q-y[/tex] then [tex]\int \frac{1}{u}dy[/tex] right? So why doesn't... d = lnu y because [itex]\int dy[/itex] = y and [itex]\int\frac{1}{u}[/itex] = ln u ? Where is my mistake? |
| Apr28-12, 01:39 PM | #17 |
Mentor
$$\int\frac{1}{q-y}\,dy = \int -f'(y)\,dy = \ ?$$ |
| New Reply |
| Thread Tools | |
Similar Threads for: Finding the intergral function (dy/dt = a(q-y))
| Finding the intergral function (dQ/dt) = kQ | Calculus & Beyond Homework | 8 | ||
| Finding the harmonic function of a function? | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Finding the Probability distribution function given Moment Generating Function | Calculus & Beyond Homework | 7 | ||
| Help with finding the volume of a triangle using definite intergral | Calculus & Beyond Homework | 10 | ||
| Finding constants in a piecewise function that allow the function to be differentiabl | Calculus & Beyond Homework | 5 | ||
