| New Reply |
Variations in the strength of gravity throughout the earth |
Share Thread | Thread Tools |
| Apr27-12, 04:23 AM | #1 |
Which parts of the earth is gravity stronger than usual, at higher points on the earth is the gravity stronger or weaker than the lower points and why?
| Apr27-12, 06:58 AM | #2 |
hello elijah18259! welcome to pf!
![]() see the explanations and pictures at http://en.wikipedia.org/wiki/Gravity_of_Earth (particularly the rotating http://en.wikipedia.org/wiki/File:GR..._animation.gif )
| Apr27-12, 05:09 PM | #3 |
As a contributer to physics forums and a teacher interested in hearing the opinions of others can I say that it is very disappointing to find a query being directed straight to Wikipedia.
I thought this was against the standards expected here. |
| Apr27-12, 05:21 PM | #4 |
Variations in the strength of gravity throughout the earthIt is QUITE common (and I think absolutely appropriate) in such situations to point someone to something they could have found on their own with little or no effort. |
| Apr27-12, 05:25 PM | #5 |
Mentor
| Apr27-12, 08:20 PM | #6 |
Recognitions:
Where such preliminary research has not been done, replying on this forum by link to a good reference is an excellent response. It shows the questioner appropriate methods for getting a rapid resolution and, probably, a more authoritative answer. |
| Jul20-12, 01:05 PM | #7 |
Mentor
If a source exists that contains accurate information, it is very appropriate to refer someone instead of re-typing all of the information. Why re-create the wheel? Also, tt's source contains visual aids.
And it does sound like homework. |
| Jul20-12, 01:16 PM | #8 |
Not sure if I understand the question right, and we have seen it in regular intervals. One possible answer is that Earth gravity is strongest at the core mantle boundary.
![]() Laurent Hodges 1991, "Gravitational field strength inside the Earth", American Journal of Physics -- October 1991 -- Volume 59, Issue 10, pp. 954-955 |
| Aug11-12, 03:49 AM | #9 |
so indicating the page not only helps the OP, it also helps other readers studying the same topic ![]() also some wikipedia entries are very good |
| Aug23-12, 09:15 AM | #10 |
Thank you everyone.
| Aug23-12, 10:42 AM | #11 |
| Aug23-12, 11:45 AM | #12 |
It also depends on the density of the mantle and crust beneath a surface. Measurements of the gravity of the earth is called gravitational tomography”. Measurements have been made and analyzed. One approximate “rule of thumb” is that the continental rock has on average less density than deep sea floor rock. The continents are basically floating on the mantle, while the deep sea floor is mantle. However, the surface of the continent is further from the center of the earth than the sea floor. So the gravitational pull of the earth is less on the surface of a continent then above the deep sea floor. Similarly, the gravitational pull on top of a mountain is less than the gravitational pull on the surface next to it. This rule isn’t exact. Therefore, lots of measurements have been made to find out exactly how the density beneath the surface varies. Here are two links on gravimeter measurements. http://scintrexltd.com/downloads/GRAVGUID.pdf “A GUIDE TO HIGH PRECISION LAND GRAVIMETER SURVEYS by H.O. Seigel The formula for the general increase of g with latitude , based on the most recently accepted spheroid approximation, is given by (Moritz, 1984). in Gals (6) <see reference> This equation includes both the Newtonian attraction of the Earth as a spheroid and the centrifugal force caused by its rotation about its axis. ” http://www.gmat.unsw.edu.au/ablos/AB...per2-Greku.pdf “Abstract An outer edge of the continental mass is established by the foot of the continental slope in accordance with the UN Convention on the Law of the Sea (UNCLOS, article 76). It can be "visible" with the help of echo-sounding and seismic surveys. It is obvious that the real continental margin extends under upper layers of the abyssal ocean floor more seaward than the visible foot. The gravimetric tomography method [1] developed by us allows scientists to reconstruct the Earth’s internal geological structure with the satellite altimeter and geoid data to determine the real outer edge of the continental mass and the breadth of the territorial sea along the coastal countries.” |
| Aug23-12, 02:35 PM | #13 |
See what Grace found for gravity: ![]() source |
| Sep8-12, 01:04 PM | #14 |
Gravity varies based on altitude. The higher the altitude, the farther away from the center of the Earth. So Mt. Everest has less gravity than Grand Canyon. But the difference isn't too consequential.
| New Reply |
| Tags |
| earth gravity, wikipedia |
| Thread Tools | |
Similar Threads for: Variations in the strength of gravity throughout the earth
| Earth's Gravity if the Earth rotated the opposite direction | Astrophysics | 4 | ||
| Electric Field Strength- variations | Classical Physics | 26 | ||
| Earth has inner core surface property variations at 1km scale | Earth | 4 | ||
| gravity on mass on earth's surface vs sun-earth gravity | Introductory Physics Homework | 2 | ||
| Gravity variations | General Physics | 3 | ||
