New Reply
Debug Assertion Failed! ( Matrix Class)
Share Thread Thread Tools
Apr29-12, 03:32 PM   #1
D.Z
i tried to debug the following code and it crashes in the end at the curly bracket }
i think i have a problem in the destructor .. Can anybody tell me why this happens ??
knowing that the Matrix extends and shrinks as i wish and all the functions work perfectly..
Code:
//-------------------------------Matrix.h-----------------------------------//
#include <iostream>
#include <cstdlib>
#include <cmath>
using namespace std;
#ifndef MATRIX_H
#define MATRIX_H
class Matrix {
	friend ostream& operator <<( ostream&, const Matrix& ) ; //insertion operator
	friend istream& operator >>( istream&, Matrix& ) ; //extraction operator
public:
	Matrix(int r=2, int c=3); //Default constructor
	Matrix( const Matrix& ); //copy constructor
	~Matrix( ); //Destructor
	//int getRowNum( ) const; //gets how many rows are there in the matrix
	//int getColNum( ) const; //gets how many colunms are there is the matrix
	//int * getRow( int ) const; //gets a whole row
	//int * getCol( int ) const; //gets a whole column
	void setRowNum( int ); //changes the number of rows in the matrix and deletes the excess rows
	void setColNum( int ); //changes the number of columns in the matrix and deletes the excess columns
	void setRow( int*, int, int ); //sets a whole row to values
	void setCol( int*, int, int ); //sets a whole column to values
private:
	int row;
	int col;
	int ** arr;
#endif
//--------------------------------Matrix.cpp---------------------------//
#include "Matrix1.h"
ostream& operator <<( ostream& out, const Matrix & m )  //insertion operator
	for (int i=0; i<m.row; i++)
		for ( int j=0; j<m.col; j++)
			out<<m.arr[i][j]<<" ";
		out << endl;
    out << endl;
	return out;
istream& operator >>( istream& in, Matrix & m )  //extraction operator
			in>>m.arr[i][j];
	return in;
Matrix::Matrix(int r, int c) //Default constructor
	r>0 ? (row=r): exit(1);
	c>0 ? (col=c): exit(1);
	arr=new int* [row];
	for ( int i=0; i<row; i++)
		arr[i]=new int [col] ;
		for (int j=0; j<col; j++)
			arr[i][j]=0;
Matrix::Matrix( const Matrix& m ) //copy constructor
	row=m.row;
	col=m.col;
	arr=new int* [row];
			arr[i][j]=m.arr[i][j];
Matrix::~Matrix( ) //Destructor
		delete[] arr[i];
	delete arr;
void Matrix::setRowNum( int r ) //changes the number of rows in the matrix and deletes the excess rows
	if ( r>row)
		for ( int i=row; i<r; i++)
			arr[i]=new int [col];
			for ( int j=0; j<col; j++)
				arr[i][j]=0;
	}else if ( r<row)
		for ( int i=r; i<row; i++)
			delete [] arr[i];
	else
		cout<<"Invalid!\n";
	row=r;
void Matrix::setColNum( int c ) //changes the number of columns in the matrix and deletes the excess columns
	if ( c>col)
		int * temp=new int [c];
		for (int i=0; i<row; i++)
				temp[j]=arr[i][j];
			for ( int j=col; j<c; j++)
				temp[j]=0;
			delete [] arr[i];
			arr[i]=new int [c];
			for ( int j=0; j<c; j++)
				arr[i][j]=temp[j];
		delete [] temp;
	}else if ( c<col )
				temp[j]=arr[i][j];
			delete [] arr[i];
			arr[i]=new int [c];
				arr[i][j]=temp[j];
		delete [] temp;
	col=c;
void Matrix::setRow( int* newRaw, int size , int r ) //sets a whole row to values
	if ( size== col && r<row)
			if ( i==r)
					arr[i][j]=newRaw[j];
	}else
		cout<<"The new row size must match the columns number\n";
		exit(0);
void Matrix::setCol( int* newCol , int size, int c ) //sets a whole column to values
	if ( size == row && c<col )
			arr[i][c]=newCol[i];
	}else
		exit(0);
//--------------------------Driver.cpp-----------------------
void main()
	Matrix X;
	cout<<"X:"<< endl<<X;
	cout<<"Setting X to 5 by 3 matrix \n"<<"X:"<<endl;
	X.setRowNum(5);
	cout<<X;
	cout<<"Setting X to 2 by 3 matrix \n"<<"X:"<<endl;
	X.setRowNum(2);
	cout<<X;
	int X_row[]={1,2,3};
	X.setRow( X_row, 3, 0);
	cout<<"Setting the first row in X to values:\n"<<"X:"<<endl;
	cout<<X;
	cout<<"Setting X with only one column\nX:\n";
	X.setColNum(1);
	cout<<X;
	cout<<"Adding three more columns to X\nX:\n";
	X.setColNum(4);
	cout<<X;
thanks in Advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr29-12, 04:23 PM   #2
It is a very dangerous and usually incorrect assumption that the parts of the code that do not generate the error you just cannot seem to find are bug-free. For example, in Matrix::setRowNum and the case r>row you seem to access arr[row], arr[row+1], ... without having reserved memory for these fields previously. That's merely the first dubious part of your code that I found. I did not go through all of your code.
Since you already use c++ features, I strongly recommend using vectors (std::vector) over arrays, anyways. Usually, I would also recommend using a proper existing matrix class, but in this case I guess the intent is the actual process of writing the class.
Apr29-12, 04:41 PM   #3
D.Z
Thank you .. i let arr to arr[20] so that it contains more than enough pointers in case the user wanted to extend the Matrix.. now it is working without errors.. :) :)
Quote by Timo View Post
for now this is the only way i know for this class.. in the future when i learn vectors , i think i will discover simpler ways to do this class .. thanks for the advise ..
By the way, this is only part of the code ... i didn't attach the whole thing because it is lengthy..
Thank you
New Reply
Thread Tools
Similar Threads for: Debug Assertion Failed! ( Matrix Class)
Thread Forum Replies
PCB debug Electrical Engineering 2
Self assertion General Discussion 4
Has anyone ever failed a Physics class before Academic Guidance 23
say you failed a class... Academic Guidance 6
C++ Matrix Class :( Computing & Technology 2
