Unraveling the Mystery of Rotation in the Michelson-Morley Experiment
  • Context: Graduate
  • Thread starter Thread starter genxhis
    Experiment
The discussion focuses on the rotation aspect of the Michelson-Morley experiment and its implications for fringe shifts. The expected fringe shifts, based on the orientation of the apparatus relative to the "ether wind," were not observed, leading to confusion about the underlying physics. The participant highlights the mathematical relationship for travel time differences, T = Lv²/c³, and shares a simulation created in Mathematica that demonstrated a fringe shift of 0.37 cycles during rotation. This indicates a significant discrepancy between theoretical predictions and experimental results, challenging the concept of ether.
  • Understanding of the Michelson-Morley experiment
  • Familiarity with the concept of "ether wind"
  • Basic knowledge of fringe shifts in interferometry
  • Proficiency in using Mathematica for simulations
  • Explore the mathematical derivation of T = Lv²/c³ in detail
  • Investigate the historical context and implications of the Michelson-Morley experiment
  • Learn about modern interpretations of light propagation and ether theories
  • Experiment with Mathematica to simulate various interferometer configurations
Physics students, educators, and researchers interested in the historical experiments that shaped modern physics, particularly those studying the nature of light and the concept of ether.
genxhis
I am having difficulty understanding the rotation in the michelson-morley experiment. I tried reading from several sources, but I think I am missing something each source regards as obvious. I can understand why the travel times involved in each light path must differ by T = Lv2/c3 (approximately). But I don't understand how rotating the apparatus by 90 degrees would change anything other than which path is labeled what. In particular I don't see how this causes a fringe shift.
Science news on Phys.org
When arm A is parallel to the "ether wind", the fringe shift was expected to be in one direction; when arm A is perpendicular to the "ether wind", the fringe shift was expected to be in the opposite direction. And when arm A is at some intermediate angle, the fringe shift was expected to be somewhere in between; in particular, if the arms are at a 45-degree angle, there should have been zero fringe shift. So if you rotate the apparatus gradually, and watch the fringes as you go along, it was expected that the fringes would shift back and forth according to the angle of the arms of the interferometer with respect to the "ether wind."
But they didn't, of course... :eek:
Thanks. I understood it a bit better after reading what you said. It also gave me an idea. To make myself more confident, I made a quick simulation on Mathematica (using roughly real data) that had the fringes shifting back-and-forth by 0.37 cycles as the apparatus rotated.
  • · Replies 21 ·
  • · Replies 47 ·
  • · Replies 23 ·
