New Reply
Calculate creep elongation and stress required
Share Thread Thread Tools
May1-12, 05:41 PM   #1
A 10 inch long 316stainless steel structure is in service at 1200°F. The maximum creep elongation in service permitted is 0.05 inches in 500 hours. The minimum creep rate vs. applied stress is known at 1100 and 1300°F and given by the following equations σ = 31.91[itex]\dot{\epsilon}[/itex]^(0.1292) (1300°F) and σ = 68.23[itex]\dot{\epsilon}[/itex]^(0.1142) (1100°F). Assuming the exponent and log of the pre-exponent for 1200°F are interpolated averages of the values at 1100 and 1300° determine the maximum stress that can be used to obtain this creep lifetime. Explain the likelihood of the accuracy of this calculation in light of the data given.
2. Relevant equations
Given in problem
3. The attempt at a solution
I wrote down the 2 equations and took the log of both sides, found the equation for 1200F to be σ=46.66[itex]\dot{\epsilon}[/itex]^(146.79)
But then plugging in the strain rate (0.05/1800000s) gives me zero for stress
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
New Reply
Tags
creep, elongation, stress, temperature
Thread Tools
Similar Threads for: Calculate creep elongation and stress required
Thread Forum Replies
Creep and stress relaxation Materials & Chemical Engineering 3
concrete block weighing 20,000 lb is supported by 2 STEEL rods Engineering, Comp Sci, & Technology Homework 2
stress change tests - Creep Materials & Chemical Engineering 18
Direct stress and elongation General Engineering 1
stress/strain/elongation question Introductory Physics Homework 2
