Calculating Bridge Pillar Forces: Solving a Seesaw Problem
  • Thread starter Thread starter jjjsarnis
    Bridge Force
The problem involves calculating the forces exerted by bridge pillars when a car is parked on a uniform bridge. The bridge is 20 m long and weighs 400,000 N, with the car weighing 19,600 N positioned at a specific distance from one end.
  • Participants discuss using principles of static equilibrium, including net force and torque considerations. There is mention of applying a seesaw-like equation to relate forces and distances, though some question its applicability in this context.
The discussion is active, with participants providing insights into the conditions for static equilibrium and suggesting the formulation of equations based on forces and moments. There is acknowledgment of the need for simultaneous equations to solve for the reaction forces at the pillars.
Participants note the importance of considering both net force and net torque in static equilibrium, with some uncertainty about the presence of torque in this specific setup.
jjjsarnis
the problem reads:
a uniform bridge 20 m long and weighing 400,000 N is supported by two pillars located 3 m from each end. if a 19,600 N car is parked 8 m from one end of the bridge, hoe much force does each pilliar exert?
i was thinking about using something like (W1)(d1) = (W2)(d2) that we used early for a seesaw problem. also if the sum of forces could be added up to equal zero and place it in equilibrium.
thanks for any help
Well you're sort of on the right track. First of all, the net force would be zero. This is because the system is in static equilibrium. I'm not sure which seesaw problem you're referring to but (W1)(d1) = (W2)(d2) would not help. If a system is in static equilibrium, there are two things that must be true. First of all, the net force is zero. What is the other one?
Consider the forces acting on the bridge. You should have the weight of the car and two normal reaction forces (one each from each of the pillars). Make a simple equatio relating those three forces. Now consider moments about one of the pillars (it doesn't matter which, just pick one). Make another equation for the balance of the moments. Now you have two simple simultaneous equations in two variables (the two reaction forces). Solve for them and you have your answer.
thanks guys, the other thing in static equilibrium would be net torque would equal zero but i didnt think there was any torque in this sytem, thanks again for your help
Great job!
10K
19K
12K
