| New Reply |
the balloon analogy (please critique) |
Share Thread | Thread Tools |
| May14-12, 09:52 AM | #52 |
Recognitions:
the balloon analogy (please critique)In the balloon it is clear that the geodesics of the subspace - great circles - are not geodesics of the embedding space, which would be straight lines. Same with FRW space, proper distance is measured along geodesics of the subspace, which are not geodesics of spacetime. |
| May14-12, 01:49 PM | #53 |
Cosmological distance is defined as the sum of a set of rulers which happen to be laid exactly end to end at a particular cosmological time which directly corresponds to the ruler on a sheet of paper. ... |
| May14-12, 02:03 PM | #54 |
From post #49
How can they have relative velocity if the cosmological moment in time is fixed? Ich: |
| May14-12, 03:10 PM | #55 |
pHinds
sorry for all this, discard what you like..my last comments!!! Regarding your Balloon Analogy website I like it! Well done....It should get put in FAQ in these forums [1] Should the balloon analogy be linked to the FLRW model?? I'm unsure. Ich seems to think in a post here it is. I think you should mention there are not precise measures of distance and time in cosmology....we use conventions to allow us to make agreed upon measures, standard comparisons. But overall, the arbitray split between space and time of different observers leads to 'ambiguity' [using a word in the wiki reference]. Under "third local effect" : [3] In your description, Second Size shape: [4] Cosmological Time: How do we say in a sentence or two, and should we bother here, that Cosmological time is the elapsed time since the Big Bang according to the clock of an observer comoving with the CMBR ...[we use the cosmological time parameter of comoving coordinates because it's convenient mathematically. There are other time measures that could also be used.] In the Wikipedia link above, cosmological time, the 'age of the universe', is the like the time of light transit along the red curve, about 13B years, not the transit time along today's orange curve distance which is about 28B years. [4] Under OTHER NOTES How about a few sentences like this : "Sending a light signal from one penny [galaxy] to another will take longer than if the pennies were stationary with respect to each other because the distances between them are increasing. [DUH!] Because the actual rate of expansion is not constant over all of cosmological time, the Hubble 'constant' varies over time since the big bang, and the actual transit time between pennies is different today than it was at earlier times. The current expansion of the universe proceeds in all directions as determined by the Hubble constant today, but it is a 'constant' in all directions of space not over time. |
| May14-12, 03:43 PM | #56 |
Paul |
| May14-12, 03:52 PM | #57 |
http://apod.nasa.gov/apod/ap090921.html See also the Integrated Sachs-Wolfe Effect: http://en.wikipedia.org/wiki/Sachs%E...93Wolfe_effect |
| May14-12, 04:48 PM | #58 |
On distance analogy:
I have three [oops, four] perspectives that I am trying to sort thru regarding the appropriatness [accuracy] of the balloon analogy to FLRW metric. A second related point is this which I already posted: #3: I happened to be rereading LineWeaver and Davis since I haven't in a long time and they make this interesting statement: #4: My last issue is the earlier posted point from Wallace regarding acceleration not velocity [or rapidity if your prefer] as the determining factor in separation. The balloon analogy does NOT capture that but how to explain in simple terms why is not yet clear to me... |
| May14-12, 05:06 PM | #59 |
George:
me: |
| May14-12, 05:16 PM | #60 |
That is however very different to saying the rate of increase of distance between his home and the aphids only depends on the acceleration. |
| May14-12, 05:25 PM | #61 |
| May15-12, 02:54 AM | #62 |
Recognitions:
The acceleration is [itex]\ddot a[/itex], here the proper radial acceleration of the balloon surface. Now if you put two dots at rest wrt each other on the surface (i.e. not comoving), their relative acceleration is proportional to [itex]\ddot a[/itex], not [itex]\dot a[/itex]. That holds in FRW coordinates as well as in the analogy. I'll open another thread for the distance definition subtleties, that doesn't belong here. |
| May15-12, 05:56 PM | #63 |
Ich, George,,,thanks for the feedback....appreciate it....
will reread your explanations tomorrow and be back then..... But not until I walk my Yorkies...after all, this is JUST science...!! Idea of a separate discussion on distance is good..... look forward to that! |
| May16-12, 12:34 PM | #64 |
George's Ned Wright link posted above did not 'click' for me after an initial reading so I was doing some background reading and came across this Wikipedia discussion which seems to support my own incorrect interpretation.... not what George claimed for Wright...but in all honestly, Wright's explanation link and this one below are not really clear to me yet:
http://en.wikipedia.org/wiki/Comovin...roper_distance [QUOTE]...It is important to the definition of both comoving distance and proper distance in the cosmological sense (as opposed to proper length in special relativity) that all observers have the same cosmological age. For instance, if one measured the distance along a straight line or spacelike geodesic between the two points, observers situated between the two points would have different cosmological ages when the geodesic path crossed their own world lines, so in calculating the distance along this geodesic one would not be correctly measuring comoving distance or cosmological proper distance. Comoving and proper distances are not the same concept of distance as the concept of distance in special relativity. This can be seen by considering the hypothetical case of a universe empty of mass, where both sorts of distance can be measured. When the density of mass in the FLRW metric is set to zero (an empty 'Milne universe'), then the cosmological coordinate system used to write this metric becomes a non-inertial coordinate system in the flat Minkowski spacetime of special relativity, one where surfaces of constant time-coordinate appear as hyperbolas when drawn in a Minkowski diagram from the perspective of an inertial frame of reference.[4] In this case, for two events which are simultaneous according the cosmological time coordinate, the value of the cosmological proper distance is not equal to the value of the proper length between these same events,(Wright) which would just be the distance along a straight line between the events in a Minkowski diagram (and a straight line is a geodesic in flat Minkowski spacetime), or the coordinate distance between the events in the inertial frame where they are simultaneous.....[/QUOTE Maybe this is better saved for a subsequent discussion on distance.....I did want to post it for future reference. I assume I am the one that is 'mixed up' and will continue background reading... |
| May16-12, 03:50 PM | #65 |
Recognitions:
Sorry for the delay, I'll start the other thread tomorrow (I hope). Again, it will go along the line of Ned Wright's arguments.
For the time being: a spacelike geodesic is not the same as a geodesic of space. The former is a geodesic of spacetime which is, well, spacelike. The latter is a curve of extremal distance in some subspace of spacetime, which is necessarily spacelike but not necessarily also a geodesic of spacetime. |
| New Reply |
| Thread Tools | |
Similar Threads for: the balloon analogy (please critique)
| Effort to get us all on the same page (balloon analogy) | Cosmology | 468 | ||
| Does a balloon's temperature increase when a balloon is popped? | Introductory Physics Homework | 4 | ||
| balloon within a balloon question | General Astronomy | 4 | ||
| Balloon Analogy | Cosmology | 1 | ||
| analogy from the GRE | General Discussion | 43 | ||
