Magnitude of Force to move blocks
The problem involves determining the force required to move two blocks connected by a rope, each with a specified weight and static friction coefficients. The original poster is attempting to understand how to calculate the total static friction that must be overcome to initiate movement.
  • Participants discuss considering the blocks as a single system and calculating the total friction force. There are attempts to clarify the relationship between static friction coefficients and the forces involved, with some questioning the provided coefficients and their application.
The discussion is ongoing, with participants exploring different interpretations of how to approach the problem. Some guidance has been offered regarding the calculation of frictional forces, but there is no explicit consensus on the method to be used.
There is a mention of needing to know the coefficients of static friction for each block, and participants are discussing the implications of these values on the overall friction force. The original poster has not provided all necessary details, which may affect the analysis.
ncrowley1818
I have a homework problem, that is giving me some trouble.
I have to move two blocks that weigh (1.2kg), connected by a rope. They give static friction coefficients for each block. I know that I must overcome the static frictions to make them move. I think I need to add the coefficients and then do something with the weight of the blocks?? Any comments or help?
Thanks,
Nick
Try considering the two blocks as a single system. What's the total friction force on the system just before it begins to move?
I can add the static forces together .55+.4=.95 total static friction
I cannot comment on your answer since you did not provide the coefficients of static friction. Also: Be sure to use proper units.
the values are the coefficients of static friction on the two blocks, I added them together to get the total static friction of the total system. I know I must over come the total to make it move. F=ma?
find the force
Are you saying that each block has a mass of 1.2 Kg and the coefficients of static friction are 0.55 and 0.45?
If so, find the frictional force on each block. What's the equation relating frictional force to the coefficient of friction?
dont you take the
force of static friction/mass of object=coefficient static friction
ncrowley1818 said:
dont you take the
No. The maximum force of static friction between two surfaces is given by:
[itex]f = \mu N[/itex], where N is the normal force pressing the surfaces together. For a block on a horizontal surface the normal force equals the weight of the block (mg), so [itex]f = \mu mg[/itex].
  • · Replies 23 ·
