Velocity and acceleration question
The discussion revolves around a physics problem involving velocity and acceleration, specifically focusing on an object's motion starting from rest, accelerating, moving at a constant speed, and then decelerating. Participants are exploring the implications of acceleration and how it affects distance and velocity over time.
  • Mixed
  • Participants are attempting to calculate distance and velocity at various stages of motion, questioning the application of acceleration in different contexts. There is confusion regarding the transition from acceleration to constant velocity and then to deceleration.
Some participants have provided clarifications regarding the definitions of acceleration and average velocity, while others are verifying their calculations and reasoning. There is an ongoing exploration of how velocity changes over time and the implications of deceleration.
Participants are grappling with the definitions and applications of acceleration, particularly in relation to the problem's constraints and the sequence of motion described. There is a focus on understanding the relationship between velocity, acceleration, and time without reaching a definitive conclusion.
missrikku
Hello, I am having trouble deciphering the following problem:
You start from rest at point i: First, moving at 30 degrees north of due east:
1. increase your speed at 0.400 m/s^2 for 6.00s
okay, with this information i did:
V = Vo + at --> V = 0 + (0.400)(6.00) = 2.40 m/s
V = d/t --> 2.40 = d/6.00 --> d = 14.4 m
2. with whatever speed you then have, move for 8.00 s
Okay, that "whatever speed" I found to be 2.40 m/s. Moving along for 8.00 s, I was thinking that I could do:
V = d/t --> 2.40 = d/ 8.00 -- > d = 19.2 m
3. then slow at 0.400 m/s^2 for 6.00s.
Okay, here is where I get confused. I thought that in parts 1 AND 2, you were still going at the same speed and thus same acceleration. So, why or how could you SLOW at 0.400 m/s^2 when that was the a given in 1?
Could someone explain to me what exactly is going on? thanks!
There is an error here. You found the final velocity, which is half the problem. The answer did ask you for the final velocity, but you applied it the wrong way in the second step. To find the distance traveled you must use average velocity. The object did not travel at 2.4 m/s for 6 seconds, he accelerated at 0.4 m/s^2 for 6 seconds (i.e. he was not traveling at 2.4 m/s the whole time). v is the average velocity:
v = 0.5(vf+v0)
I'll let you solve it.
The second step is fine.
I think what is confusing you is your definition of acceleration (which is wrong). acceleration is how much your velocity changes. when you are accelerating at 0.4 m/s2 that means you are increasing your velocity by 0.4 m/s every second. if you are traveling at a constant velocity (i.e. 2.4 m/s) than your acceleration is 0 m/s2. In this problem the object accelerates .4 m/s every second for 6 seconds. Then it stays at that constant velocity for eight seconds (no acceleration) and then it begins to accelerate at -0.4 m/s2 (or if you like deaccelerate at 0.4 m/s2)
#EDIT: *Sigh* I'm such an idiot. i accidentally added a t in the equation for average velocity (which would make it an equation for distance (s)). It's now corrected.
-HBar
Okay, thanks much! I just wanted to check if so far I'm doing this right. So, because it is deaccelerating in part 3, can I do the following:
X-Xo = Vot + 0.5at^2 = (2.40)(6.00) + 0.5(-0.400)(6.00)^2 = 7.20 m
But then, if I do:
V = Vo + at
V = 2.40 + (-0.400)(6.00) = 0
So how can that be that there is no velocity at that point?
X-Xo = volt + 0.5at^2 = (2.40)(6.00) + 0.5(-0.400)(6.00)^2 = 7.20 m
But then, if I do:
V = Vo + at
Okay. If the object starts out with zero velocity, gains velocity at a given rate for a given time, and then later loses velocity at the same rate for the same amount of time, then of course it is going to have zero velocity at the end.
  • · Replies 33 ·
