Integrating Triple Integral: θ, r, z
The discussion revolves around evaluating a triple integral involving variables θ, r, and z, specifically integrating over a defined region in cylindrical coordinates. Participants explore the implications of symmetry in the integration limits and the behavior of the integrand, particularly focusing on the function sin³θ and its properties.
  • Participants discuss the correctness of their integration steps and the impact of changing limits of integration on the final result. They question the validity of using symmetry to simplify the integral and explore the implications of odd and even functions in their calculations.
Some participants have provided insights into the nature of the integrand and the symmetry of the region of integration. There is an ongoing exploration of the assumptions made regarding the limits of integration and the properties of the functions involved, with no explicit consensus reached on the best approach yet.
Participants are navigating the complexities of integrating functions that exhibit odd and even properties, as well as the implications of symmetry in the integration process. The original problem setup and the specific limits of integration are under scrutiny, with some participants expressing uncertainty about the correctness of their methods.
cjc0117
Hi everyone. I am trying to integrate the following:
[itex]\int^{\frac{π}{2}}_{-\frac{π}{2}}\int^{acosθ}_{0}\int^{\sqrt{a^{2}-r^{2}}}_{-\sqrt{a^{2}-r^{2}}}rdzdrdθ[/itex]
Here's my work:
[itex]=2\int^{\frac{π}{2}}_{-\frac{π}{2}}\int^{acosθ}_{0}r\sqrt{a^{2}-r^{2}}drdθ[/itex]
I use substitution with u=a2-r2 to get:
[itex]=-\int^{\frac{π}{2}}_{-\frac{π}{2}}\int^{a^{2}sin^{2}θ}_{a^{2}}u^{\frac{1}{2}}dudθ[/itex]
[itex]=-\frac{2}{3}a^{3}\int^{\frac{π}{2}}_{-\frac{π}{2}}(sin^{3}θ-1)dθ[/itex]
[itex]=-\frac{2}{3}a^{3}\int^{\frac{π}{2}}_{-\frac{π}{2}}sin^{3}θdθ+\frac{2}{3}a^{3}\int^{\frac{π}{2}}_{-\frac{π}{2}}dθ[/itex]
sin3θ is an odd function so the first integral is equal to zero:
[itex]=\frac{2}{3}a^{3}\int^{\frac{π}{2}}_{-\frac{π}{2}}dθ[/itex]
[itex]=\frac{2}{3}πa^{3}[/itex]
However, I have seen other solutions online that give the actual answer as 2a3(3π-4)/9. The authors of these solutions change the limits of integration of the original triple integral by taking advantage of symmetry. More specifically, I noticed that the person changed the limits of θ from 0 to π/2 by multiplying the integral by 2. Then when you get to the point when you integrate sin3θ, the integral no longer equals zero. However, I thought you could only do this if the region of integration has no θ dependence. And in any case, why should it matter whether I change the limits of integration or not? It's still the same integral, right? I have a feeling I'm making a very dumb mistake somewhere but I can't find out where. Thanks for any help.
Your integral is correct.
You could also have used the multiple angle formula to convert sin3θ into sin(3θ) or used the substitution: let u = cosθ.
Here's my work:
You didn't make a dumb mistake, but it is a mistake nevertheless, sort of a subtle one. The problem is where you have $$
u^{\frac 3 2}|_{a^2}^{a^2\sin^2\theta}$$and you substitute the ##a^2\sin^2\theta## in for the ##u##. That gives you $$
(a^2\sin^2\theta)^{\frac 3 2}$$That does not simplify to ##a^3\sin^3\theta## when ##\theta## is between ##-\frac \pi 2## and ##0## because ##a^2\sin^2\theta\ge 0## and when you raise it to the 3/2 power it must be nonnegative. It's the old problem that ##\sqrt{x^2}= |x|##, not ##x##. What it does simplify to is ##a^3|\sin^3(\theta)|##, which is not an odd function and doesn't give ##0## in later steps.
Thanks LCKurtz. That ,makes sense. Now what I don't understand is this:
[itex]\int^{\frac{π}{2}}_{-\frac{π}{2}}\int^{acosθ}_{0}\int^{\sqrt{a^{2}-r^{2}}}_{-\sqrt{a^{2}-r^{2}}}rdzdrdθ=4\int^{\frac{π}{2}}_{0}\int^{acosθ}_{0}\int^{\sqrt{a^{2}-r^{2}}}_{0}rdzdrdθ[/itex]
It makes sense to me with the integral with respect to z, since the region of integration is symmetrical about the xy-plane, and f(θ,r,z)=r is even with respect to z. As for the integral with respect to θ, I realize that the region of integration is also symmetrical about the yz-plane, but I am not immediately inclined to think that the function f(θ) being integrated at that time will be even with respect to θ. How can you tell? Am I even thinking of symmetry in the right way?
EDIT: Is it because g(θ)=acosθ is even with respect to θ, so any composite function f(g(θ)) that results from the integration with respect to r will also be even?
##\cos\theta## is even and any function of an even function is even. See if you can prove that.
Let x=g(t) be an even function, that is, x=g(t)=g(-t). Then f(x)=f(g(t))=f(g(-t)) must also be an even function.
Is that a sufficient proof? It sounds more like a conclusion.
That's about all there is to it. I would write it like this: Let ##h(t) = f(g(t))##. You want to show ##h(t) = h(-t)##. So calculate ##h(-t)##:
##h(-t) = f(g(-t)) = f(g(t))\hbox{ (since g is even) } = h(t)##.
Okay, thanks again. This problem was driving me insane before but it's all clear now.
  • · Replies 19 ·
  • · Replies 105 ·
13K
  • · Replies 21 ·
