Difficulty to find this integral
The integral \(\int \sqrt{2ax}\; dx\) can be solved using substitution methods. The correct substitution is \(u = 2ax\), leading to the integral \(\int u^{\frac{1}{2}}\; du\). The solution results in \(\frac{2}{3}u^{\frac{3}{2}} + C\), which simplifies to \(\frac{2}{3}(2ax)^{\frac{3}{2}} + C\). It is essential to clearly state the substitution used to avoid confusion in the solution process.
  • Understanding of integral calculus
  • Familiarity with substitution methods in integration
  • Knowledge of basic algebraic manipulation
  • Ability to work with exponents and roots
  • Study substitution techniques in integral calculus
  • Practice solving integrals involving square roots
  • Learn about the properties of definite and indefinite integrals
  • Explore advanced integration techniques such as integration by parts
Students learning calculus, particularly those struggling with integration techniques, and educators looking for examples of integral solutions.
DDarthVader
Hi! I'm not being able to solve this integral: [tex]\int \sqrt{2ax}\; dx[/tex] We have started with integral yesterday and I don't know much yet.
This is what I tried to solve the integral
[tex]\int \sqrt{2ax}\; dx = \int u^{\frac{1}{2}}\; du = \frac{2}{3}{}u^{\frac{3}{2}}=\frac{2}{3}\sqrt[3]{(2ax)^2}[/tex]
Assuming that a is a real constant,
[tex]\int \sqrt{2ax}\; dx = \int \sqrt{2a}\sqrt x\; dx= \sqrt{2a} \int \sqrt x\; dx[/tex]
Since [itex]\sqrt x[/itex] is the same as [itex]x^{\frac{1}{2}}[/itex], you can easily find its integral, and then multiply by [itex]\sqrt {2a}[/itex] to get the final answer.
When you use a substitution, as you obviously did above, you need to write down what the substitution is. IOW, you should have u = <...> somewhere close by.
Also, u3/2 = ##\sqrt{u^3}##, not ##\sqrt[3]{u^2}##, which is what you had.
  • · Replies 22 ·
  • · Replies 105 ·
13K
  • · Replies 21 ·
