Acid-Base Titrations and Liquid Soap
  • Thread starter Thread starter arthur_
    Liquid Soap
The discussion revolves around the challenges of performing acid-base titrations on liquid soap, specifically focusing on the measurement of Sodium Lauryl Ether Sulphate (SLES) and the potential interference of buffers present in soap formulations.
  • Experimental/applied
  • Arthur inquires whether the presence of buffers in soap affects the results of acid-base titrations and seeks advice on how to address this issue.
  • Chemisttree asks for clarification on what specifically Arthur is trying to measure.
  • Arthur clarifies that he is attempting to measure Sodium Lauryl Ether Sulphate (SLES).
  • One participant notes that buffers can behave as acids or bases depending on pH and the chosen indicator, suggesting that if a buffer is present, the titration may measure the buffer rather than the acid form of SLES.
  • This participant speculates on the pKa of the monoester of lauryl ether sulfate, suggesting it might be around -2 to -3, and indicates that if the soap's pH is near neutral, SLES would exist primarily as an anion.
  • Another participant suggests that to measure SLES accurately, one might consider measuring the critical micelle concentration (CMC) of dilutions instead of performing a titration.
  • It is stated that SLES cannot be measured by aqueous titration without excluding known buffering materials, and that complexing agents may help in analytical methods.
  • Non-aqueous titration is mentioned as an alternative, requiring exclusion of water to work effectively, and the presence of other surfactants complicates the determination of individual surfactants in the mixture.
  • Alternative methods such as NMR and other spectrometric techniques are recommended for analyzing unknown soap compositions.
Participants express differing views on the feasibility of measuring SLES through titration, with some suggesting it is not possible under typical conditions due to buffering effects, while others propose alternative methods without reaching a consensus on the best approach.
The discussion highlights limitations related to the presence of buffers and surfactants in soap, the need for specific conditions to perform titrations, and the potential for alternative analytical methods to provide clearer results.
arthur_
I am doing an acid-base titration on liquid soap. I understand that buffers are used in soap. Would that affect the results of my titration? If so, how would I overcome this?
Arthur.
Chemistry news on Phys.org
What are you trying to measure?
sorry for the delay, chemisttree.
i'm trying to measure Sodium Lauryl Ether Sulphate
Buffers can titrate as acids or bases depending on the pH and the indicator you use. If a buffer is added to soap, you will be titrating buffer rather than the acid form of 'SLES'. I don't know the pKa of the monoester of lauryl ether sulfate but I'm guessing it is somewhere around -2 to -3. If you measure the pH of your soap and it is near neutral, you can be sure that all of the lauryl ether sulfate exists as the anion. You will simply be titrating the buffer
If you are actually trying to measure the SLES by titration, I would suggest that you instead measure the critical micelle concentration of a series of dilutions and back-calculate the initial concentration.
so i cannt measure the SLES by titration?
Not by an aqueous titration, and not without a set of conditions that can exclude the known buffering materials (those one can expect in the soap product). Most buffers can be expected as inorganic salts, and their interference might be removed by complexing agents in analytical methods found in the literature.
A nonaqueous titration uses a different solvent that presents a stronger conjugate acid than H3O(+) in the equilibrium. Water has to be rigidly excluded for these titrations to work.
The presence of other surfactants may make it difficult to determine one surfactant in the mix by CMC. These could be non-ionic, anionic, and cationic. If your soap is indeed an unknown, then other methods should be used that are more unequivocal. (NMR, other spectrometric methods).
  • · Replies 40 ·
