Why Choose an I Section Over a Square Section for Load-Bearing Applications?
  • Thread starter Thread starter Analysis
    Section Square
The discussion revolves around the technical advantages of using I sections over square sections in load-bearing applications, particularly in the context of static loads and bending stresses. Participants explore various factors influencing the choice of beam shape, including structural efficiency, design aesthetics, and practical considerations in manufacturing and application.
  • One participant notes that I sections are advantageous for bending loads due to their structural efficiency, despite the higher area moment of inertia of square sections.
  • Another participant mentions aesthetic considerations and ease of maintenance as reasons for choosing square sections, particularly in designs where bending occurs in multiple planes.
  • A different viewpoint emphasizes that I beams have less volume and weight compared to square sections of the same dimensions, which can be beneficial for bending moment considerations.
  • One participant lists conditions under which I beams may not be suitable, including difficulties in manufacturing smaller sections and poor performance under transverse loads.
Participants express differing opinions on the advantages of I sections versus square sections, indicating that multiple competing views remain. The discussion does not reach a consensus on the best choice for all scenarios.
Some limitations include the dependence on specific application requirements, manufacturing capabilities, and the nature of the loads acting on the beams, which are not fully resolved in the discussion.
Analysis
Dear all
Apart from cost saving (or reduction in material)what is the technical advantage using I section instead of square section?
My application is,section is going to be simply supported to the static load.myself awared that I section is good for bending loads.Instead i am using square section,so my area moment of inertia will be high,the bending stress would be low.
Kindly comment the above subject.
Thanks
Prakash
I use square sections when I want a cleaner or more attractive design, or when I have a bending component in the other plan. Less surface area collects less dust and is easier to wash down. When galvanizing less surface area uses less and is easier to ensure a uniform coating.
The most important reason to use an "I beam" (or "I section") is that it has much less volume and so much less weight than a square section of the same dimensions. And, since such things as "bending moment" depend upon the length in varying directions rather than volume, you don't lose strength.
I beam definitely is an obvious choice for situations where bending moment is of prime concern. As long as following conditions are not true, you can always go for I-beam:
1: Manufacturing: Normally i beams are not available in smaller section and hard to join (welding etc)
2: I beam is a poor choice where you have loads acting transversely to the length of beam.
10K
12K
