Parallel propagator and covariant derivative of vector
The discussion revolves around the relationship between connection coefficients (Christoffel symbols), the parallel propagator, and the covariant derivative of vectors in the context of differential geometry and general relativity. Participants explore theoretical aspects, mathematical formulations, and the implications of these concepts without reaching a consensus.
  • One participant seeks to understand how the connection coefficients, the propagator, and the covariant derivative are linked, presenting various mathematical formulations.
  • Another participant questions the relationship between propagators and curvature connections, suggesting that propagators are linear and providing a definition of a bitensor.
  • Some participants argue against the characterization of the propagator as a bitensor, stating that it maps vectors between different vector spaces rather than acting within a single space.
  • There is a discussion about the mathematical expressions for the covariant derivative and attempts to derive one expression from another, with references to specific equations and notations.
  • One participant expresses uncertainty about the nuances of the derivation process and acknowledges potential gaps in their reasoning.
  • Clarifications are made regarding the nature of the propagator and its relation to the covariant derivative, with references to external resources for further understanding.
Participants express differing views on the nature of the propagator and its classification as a bitensor. There is no consensus on the relationship between the various mathematical expressions discussed, and the discussion remains unresolved.
Participants note the complexity of the relationships involved and the potential for missing nuances in the derivations presented. The discussion includes references to specific mathematical expressions and definitions that may require further clarification.
ianhoolihan
Hi all,
I'm trying to figure out the link between the connection coefficients (Christoffel symbols), the propagator, and the coordinate description of the covariant derivative with the connection coefficients.
As in http://en.wikipedia.org/wiki/Parall...ng_the_connection_from_the_parallel_transport one can write
[tex] \nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - V_{\gamma(0)}}{h}= \frac{d}{dt}\left. \Gamma(\gamma)_t^0V_{\gamma(t)}\right|_{t=0}[/tex]
However, we also know that
[tex] \nabla_b V^a = \partial_b V^a + {\Gamma^a}_{cb}V^c.[/tex]
I understand how, in some loose sense, one can think of the connection coefficients as the derivative of the parallel propagator:
[tex] {\Gamma^a}_{cb} = \left.\frac{\partial}{\partial y^c}{[\Gamma(\gamma)^x_y]^a}_b\right|_{y \to x}.[/tex]
However, I cannot see how to link the three together, and formalise things. Carrol's notes (http://preposterousuniverse.com/grnotes/grnotes-three.pdf ) give a hint, but without using the first sort of equation I gave--- he just jumps in with the second equation as an "assumption". What I'd ultimately be looking to do would be something like using the product rule:
[tex] \nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - \Gamma(\gamma)^0_0V_{\gamma(0)}}{h}[/tex]
[tex] \nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - \Gamma(\gamma)_0^0V_{\gamma(h)}+\Gamma(\gamma)_0^0V_{\gamma(h)}-\Gamma(\gamma)_0^0V_{\gamma(0)}}{h}[/tex]
[tex] \nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - \Gamma(\gamma)_0^0V_{\gamma(h)}}{h}+\lim_{h\to 0}\frac{\Gamma(\gamma)_0^0V_{\gamma(h)}-\Gamma(\gamma)_0^0V_{\gamma(0)}}{h}[/tex]
[tex] \nabla_X V =V_{\gamma(h)}\frac{d}{dt}\left.\Gamma(\gamma)^t_0\right|_{t=0} +\Gamma(\gamma)^0_0\frac{d}{dt}\left.V_{\gamma(t)}\right|_{h=0}[/tex]
So, that somehow
[tex] \nabla_b V^a =V^c_{\gamma(0)}{\Gamma^a}_{cb} +\partial_b V^a_{\gamma(0)}[/tex]
However, this makes no sense, as it means you are subtracting vectors from different vector spaces (the whole reason the parallel propagator was introduced in the first equation I gave in this post). I've also jumped straight to coordinate components...
Any bright ideas would be much appreciated.
Cheers,
Ianhoolihan.
I just received an email that a post had been added, though it appears not to be here ?
The post in the email read:
I fail to see the relation between propagators and curvature connections, propagators are linear, aren't they?
Could you clarify?
As far as I am concerned, the propagator [itex]\Gamma(\gamma)_h^0[/itex] is a bitensor that takes a vector from [itex]T_{\gamma(h)}(M)[/itex] to [itex]T_{\gamma(0)}(M)[/itex]. I am not an expert by any means, but I guess they are linear in the sense that
[tex]\Gamma(\gamma)_h^0 \left(V_{\gamma(h)} + W_{\gamma(h)}\right) = \Gamma(\gamma)_h^0\left(V_{\gamma(h)}\right)+ \Gamma(\gamma)_h^0\left(W_{\gamma(h)}\right)[/tex]
Does that make sense?
Ianhoolihan
I don't think the propagator can be considered a bitensor because it takes a vector and maps it to a vector in another space whereas a tensor "lives" in one space and so acts only one vectors and oneforms in that one space. The parallel propagator is simply a mapping between different vector spaces.
I'm not entirely sure what you're going for.
To quote Eric Poisson http://relativity.livingreviews.org/open?pubNo=lrr-2011-7&page=articlese15.html
... bitensors, tensorial functions of two points in spacetime.
I see your point, but is not a bitensor another way of describing a map from one vector space V1 to another V2? It "lives" in both spaces. For example you could write the one--form part of the bitensor as a one--form in V1*, and the vector part as a vector in V2...
I need to read the above link in more detail (having just found it), but for reference, here are the notes I have been using: http://msor.victoria.ac.nz/twiki/pub/Courses/MATH465_2012T1/WebHome/notes-464-2011.pdf
See section 3.2 on the parallel propagator. (It is called a bitensor here.)
OK, I guess I could have been clearer. I have two expressions for the covariant derivative:
[tex]\nabla_X V = \lim_{h\to 0}\frac{\Gamma(\gamma)_h^0V_{\gamma(h)} - V_{\gamma(0)}}{h}= \frac{d}{dt}\left. \Gamma(\gamma)_t^0V_{\gamma(t)}\right|_{t=0}[/tex]
and
[tex]\nabla_b V^a = \partial_b V^a + {\Gamma^a}_{cb}V^c.[/tex]
I simply want to get from the first to the second.
Right, let's see if this works. Firstly, since we're working with bitensors, I'll expand on what I hinted at in the last post. To make things easier notationally, let the propagator be [itex]\Gamma(t \to t_0;\gamma)[/itex], which takes [itex]T_{\gamma(t)}(M)[/itex] to [itex]T_{\gamma(t_0)}(M)[/itex]. Then we can write it as
[tex]\Gamma(t \to t_0;\gamma) = \Gamma^{a_{t_0}}_{b_t} e_{a_{t_0}} \otimes \omega^{b_t}[/tex]
with the notation on the indices to indicate whether they are at [itex]\gamma(t_0)[/itex] or [itex]\gamma(t)[/itex]. That is [itex]e_{a_{t_0}}[/itex] are the basis vectors at [itex]\gamma(t_0)[/itex] and [itex]\omega^{b_t}[/itex] are the dual basis vectors at [itex]\gamma(t)[/itex].
Hence
[tex]\Gamma(t \to t_0;\gamma)V_{\gamma(t)} = \Gamma^{a_{t_0}}_{b_t} e_{a_{t_0}} \otimes \omega^{b_t}\left(V^{c_t}e_{c_t}\right) = V^{b_t}\Gamma^{a_{t_0}}_{b_t}e_{a_{t_0}}[/tex]
for some vector [itex]V_{\gamma(t)}[/itex]. Therefore
[tex] \left.\frac{d}{dt}\Gamma(t \to t_0;\gamma)V_t \right|_{t=t_0}=\left[\frac{d}{dt}\left(V^{b_t}\right)\Gamma^{a_{t_0}}_{b_t} + V^{b_t} \frac{d}{dt} \left(\Gamma^{a_{t_0}}_{b_t}\right)\right]_{t=t_0}e_{a_{t_0}}[/tex]
Letting [itex]x=x(t)[/itex] be the local coordinates, then
[tex]\frac{d}{dt}\left(V^{b_t}\right) = \frac{dx^{c_{t_0}} }{dt} \partial_{c_{t_0}} V^{b_t}[/tex]
and
[tex]\frac{d}{dt}\left( \Gamma^{a_{t_0}}_{b_t} \right) = \frac{dx^{c_{t_0}} }{dt} \partial_{c_{t_0}} \Gamma^{a_{t_0}}_{b_t}.[/tex]
Therefore,
[tex] \left.\frac{d}{dt}\Gamma(t \to t_0;\gamma)V_t \right|_{t=t_0}=\frac{dx^{c_{t_0}} }{dt}\left[<br /> \partial_{c_{t_0}} V^{b_t}\Gamma^{a_{t_0}}_{b_t} +<br /> V^{b_t} \partial_{c_{t_0}} \Gamma^{a_{t_0}}_{b_t}<br /> \right]_{t=t_0}e_{a_{t_0}}[/tex]
Given that
[tex] \left.\Gamma^{a_{t_0}}_{b_t}\right|_{t=t_0} = \delta ^{a_{t_0}}_{b_{t_0}}[/tex]
and defining
[tex] {\Gamma^{a_{t_0}}}_{b_{t_0}c_{t_0}}\equiv\left. \partial_{c_{t_0}} \Gamma^{a_{t_0}}_{b_t}\right|_{t \to t_0}[/tex]
then
[tex] \left.\frac{d}{dt}\Gamma(t \to t_0;\gamma)V_t \right|_{t=t_0}=X^{c_{t_0}} \left[<br /> \partial_{c_{t_0}} V^{a_{t_0}} +<br /> {\Gamma^{a_{t_0}}}_{b_{t_0}c_{t_0}}V^{b_{t_0}} <br /> \right]e_{a_{t_0}}[/tex]
or, dropping all the [itex]t_0[/itex]
[tex]\nabla_X V = \frac{d}{dt}\left. \Gamma(t\to t_0;\gamma)V_{\gamma(t)}\right|_{t=0}<br /> =X^c \left[<br /> \partial_c V^a +<br /> {\Gamma^a}_{bc}V^b <br /> \right]e_a<br /> =<br /> X^c \nabla_c V^a e_a.[/tex]
That seems alright for me, but I understand I've skipped over a few of the nuances along the way. However, I suspect if I do things in the coincidence limit of the bitensors (or something like that) this will turn out to be correct.
Thoughts?
Ianhoolihan
Yes, I deleted it, I thought you were referring to the QFT propagator. When I read your link I realized it was a different thing.
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 35 ·
12K
