New Reply
Question on Heat, Pressure, and Doppler's Effect
Share Thread Thread Tools
May10-12, 12:17 AM   #1
I have 310g mass 24°C Water and I add 85g of 0°C ice.
What is the final temperature after the ice melted and come to equilibrium?
2. Relevant equations
I think its Q=mcΔt
with a mix of Q=mL
3. The attempt at a solution
I have no idea.
I have density of air of 1.2 kg/m³. Air pressure at earth surface 1.01x10^5 Pa. I need to find the height of the atmosphere.
P=pgh
So I made the problem; 1.01x10^5=(1.2kg/m³)(9.8m/s)(height) and found for height and got 8588.435m. Is that right? I don't know what a "believable" answer would look like.
This is suppose to be a scenario where the police is using a radar to find the speed of passing cars. So, the velocity is in EM (speed of light). There is a note that says there are two Doppler shifts so I use a squared version of the formula. The Radar is bounced off the moving cars and the Doppler-shifted frequency of the echo's signal is compared to the frequency of the original signal.
The microwave frequency of 1.4x10^9 Hz is used for the original signal and the reflected signal is 350 Hz lower than that. (the car is moving away from the radar gun). What is the speed of the car in mph?
Hint: there are two Doppler shifts
freflected = (Vw/(Vw+Vcar))² f original
(1.4x10^9)-350 Hz = (3x10^8/(3x10^8+X)²(1.4x10^9)
There is something I'm missing but I dunno. I solve the [I]f[/I]reflected and divide by f original. I then square root both sides and divide Vw by freflected and solve for X
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
New Reply
Thread Tools
Similar Threads for: Question on Heat, Pressure, and Doppler's Effect
Thread Forum Replies
Sound and doppler effect on window pressure Introductory Physics Homework 0
Doppler Effect question Introductory Physics Homework 1
Doppler effect question Introductory Physics Homework 0
Question about Doppler effect Introductory Physics Homework 5
doppler effect question Introductory Physics Homework 2
