Measuring the tidal effect of the moon on the earth
The discussion centers on measuring the tidal effect of the moon and sun on Earth's gravity, specifically the minute differences in gravitational force at various times of the day. The expected gravitational difference due to the sun is approximately 10^-6 m/s^2, while the moon's effect is about three times greater. Participants suggest using pendulums or seismometers for their sensitivity to small gravitational changes, as well as laser interferometry for precise measurements. The challenge lies in obtaining equipment capable of detecting such small variations in gravity.
  • Understanding of gravitational forces and tidal effects
  • Familiarity with pendulum mechanics and sensitivity
  • Knowledge of seismometer calibration and operation
  • Basic principles of laser interferometry
  • Research pendulum design for measuring small gravitational changes
  • Explore seismometer technology and its application in gravity measurement
  • Investigate laser interferometry techniques for precision measurement
  • Study material properties relevant to gravitational experiments
Undergraduate physics majors, experimental physicists, and anyone interested in gravitational measurement techniques and tidal effects.
Pseudopod
I'm an undergraduate physics major and I want to create an experiment where I measure the difference in gravity between sunrise, noon, sunset, and midnight (and everything in between for that matter) due to the tidal effect from the moon and sun. I did some calculations and I expect the difference in gravity due to the sun to be on the order of 10^-6 m/s^2 and due to the moon to be about 3 times that.
My dilemma is how to measure that tiny difference in gravity.
I have yet to come up with a good way. Any scale I could get that's accurate enough couldn't handle the large mass needed to generate a tiny difference in force. I've thought a little about using interferometry to try to measure small variations in the deformation of a wire or a bar or something, but that still seems complicated because I'd have to know the exact properties of the material I am using.
Any ideas?
That's an interesting experiment you're trying to carry out! It certainly seems like a difficult task. Have you considered using a pendulum or a seismometer to measure the gravitational changes? Pendulums are particularly sensitive to small changes in gravity and can be relatively easy to set up. Seismometers can also be used to measure gravitational changes, although they require more calibration and may not be as precise as a pendulum. Alternatively, you could look into using lasers to measure the difference in gravity. There are a few different methods available, including laser interferometry, which can be very accurate. Good luck with your experiment!
  • · Replies 19 ·
  • · Replies 17 ·
