Register to reply
Difference between pressure and stress
by PerpStudent
Tags: difference, pressure, stress
Share this thread:
PerpStudent
#1
May13-12, 02:07 PM
P: 27
Both pressure and stress are defined in terms of force per unit area. Beyond that simple relationship, what might constitute a good intuitive way to distinguish these two concepts?
Phys.Org News Partner Physics news on Phys.org
Symphony of nanoplasmonic and optical resonators produces laser-like light emission
Do we live in a 2-D hologram? New Fermilab experiment will test the nature of the universe
Duality principle is 'safe and sound': Researchers clear up apparent violation of wave-particle duality
truesearch
#2
May13-12, 02:34 PM
P: 349
They are basically the same thing and the terms used tend to reflect context rather than physics. You would use 'Stress' when dealing with stretching etc, pressure when dealing with gases etc.
Similar 'problems' occur with Newton.metres which can mean work or energy (Joules) or moment as in turning effect and torque
sophiecentaur
#3
May13-12, 05:47 PM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,157
Quote Quote by truesearch View Post
Nm is strictly a unit of Moment. The 'Newtons times metres' that is used to calculate Work is the Scalar Product of two Vectors (Force and Displacement) and Nm should never be used to describe Work of Energy.
Pressure and stress, however, are totally equivalent and it's only the context that determines which term you want to apply to a situation. (It's not really a "problem")
Andy Resnick
#4
May13-12, 07:30 PM
Sci Advisor
P: 5,523
Quote Quote by PerpStudent View Post
Stress is a little more general than pressure- one intuitive way to think about stress is to think about how a square can be deformed. The square can be made larger or smaller (uniform expansion/compression), but also be sheared into a rhombus shape (and combinations of expansion with shear as well).
'stress' is the most general way to describe any deformation, while pressure is restricted to the uniform expansion/compression. Mathematically, pressure is the isotropic component of the stress tensor.
Register to reply
Related Discussions
Stress tensor : tension VS Pressure Special & General Relativity 1
Stress Concentration on Pressure Vessel Mechanical Engineering 0
Pressure and stress General Physics 47
Difference between Yield stress and Proportional Limit Engineering, Comp Sci, & Technology Homework 4
Stress-energy tensor and pressure Special & General Relativity 3
