Why Can't Slackware 10.0 Access My Hard Disk During Installation?
  • Thread starter Thread starter franznietzsche
The discussion revolves around issues encountered while attempting to install Slackware 10.0 on a computer that already has Windows XP and Fedora Core 3 installed. Participants explore problems related to the installer not recognizing hard disk partitions and suggest potential solutions, including kernel options and hardware configurations.
  • One participant reports that the Slackware installer fails to access the hard disk for formatting, despite the disk being recognized in Fedora.
  • Another suggests using a 2.6.x kernel during installation, although they later express uncertainty about the availability of such a kernel without a boot disk.
  • A participant mentions downloading a SATA ISO in hopes of resolving the issue, indicating a potential compatibility problem with the IDE controller.
  • There is a suggestion to install on an older PATA hard drive and then transfer the setup to the SATA drive, but one participant clarifies they only have a SATA drive available.
  • Another participant questions whether the 2.6.7 kernel is available in the testing directory and if it can be specified during installation.
Participants express multiple competing views regarding the installation issues, particularly concerning kernel compatibility and hardware recognition. The discussion remains unresolved, with no consensus on a definitive solution.
Participants mention limitations related to the availability of boot disks and kernel versions, as well as potential hardware configuration issues that may affect the installation process.
franznietzsche
I'm trying to install slackware 10.0 on my computer, as a 3rd OS, with WinXP, and Fedora Core 3 already installed.
I download the isos, check the md5s, they match. I boot from the slackware disc, and from then on its nothing but problems. For some reason fdisk will not access my hard disk to format it. I quit out, run fdisk in fedora to format the "unallocated space" as a linux partition. It works fine. I reboot on the slackware install disk. It tells me there is no swap space (there is since I'm already running fedora), and it tells me there are no linux partitions detected (there are 4 linux partitions, 1 boot, 1 root, 1 home and 1 blank that I'm trying to install slackware to.
my hard drive is at /dev/sda but it tells me its unable to access it. Again, fdisk under fedora had no problem pulling it up.
I'm completely stuck as to what to do. ANy ideas?
Also: running cfdisk just brings up a fatal error.
Computer science news on Phys.org
Run the install with a 2.6.x kernel. I think you can specify to use one when you're booting the install.'
EDIT: Come to think of it, maybe not. You'll have to use a boot disk.
/ftp://ftp.slackware.com/pub/slackware/slackware-current/bootdisks/[/URL]
or check this out
[URL=http://4elements.4mg.com/#top.]http://4elements.4mg.com/#top.[/URL]
Hope this helps :smile: :smile:
I don't get the funny...
At any rate I'm dowloading the SATA iso, hopefully that will work.
I actually don't have a floppy drive (haven't used a flppy in years, didn't expect to suddenly need one)
It sounds like Slackware isn't seeing your IDE controller. This is pretty common if you have a Promise, Adaptec, etc.
As suggested, try booting the 2.6.x kernel and see what happens. Perhaps the Slackware developers decided to compile in support for your IDE controller.
well the sata.i did nothing to fix the problem.
how do i run the install with 2.6.x? i can't find anything on how to do this.
or check this out
Hope this helps :smile: :smile:[/QUOTE]
those boot disks are all kernel 2.4, is there actually anyway to boot 2.6 to install from? as far as I've found there is not. I can't even find a similar case of this problem anywhere.
do u have an old PATA hard drive?
You could always do an install onto that, compile a brand new 2.6.10 on it, then copy everything over to the SATA once it's setup? =o
NO i only have the SATA hard drive. i tried to set it to "legacy ATA" but i could not find any place in BIOS options to set that.
checkout http://www.linuxquestions.org/questions/showthread.php?postid=960957#post960957 thread.
I think the 2.6.7 kernel is in the testing directory on CD2. can you specifiy it during install ?
:confused:
  • · Replies 18 ·
  • · Replies 123 ·
21K
