| New Reply |
How can a diode defend the coil during transistor cutoff? |
Share Thread | Thread Tools |
| May17-12, 06:32 AM | #18 |
Recognitions:
| May17-12, 06:42 AM | #19 |
I don't know why they are doing it here seems to just be an example, I would agree with you. |
| May17-12, 06:42 AM | #20 |
| May17-12, 06:47 AM | #21 |
Recognitions:
Besides, the more voltage sources there are, the more interesting it is for students to analyze. ![]() BTW, I think your title could be "How does the diode protect the transistor during transistor cutoff?" |
| May17-12, 06:54 AM | #22 |
I mentioned that in a previous post as well - the diode definitely protects the transistor.
In another application, it could be used to protect anything electronic, anything that could be sensitive to the feedback produced by the coil during shut-down |
| May17-12, 07:33 AM | #23 |
Good catch Nascent Oxygen I was not clear.
By 'reverse' I meant that the coil developed voltage opposes the change (Lenz law as already mentioned) |
| May17-12, 07:41 AM | #24 |
Your circuit diagram shows the pretty conventional practice of taking a connection in the circuit to a suitable voltage supply, without detailing where that supply comes from. So the 12 volts DC could be derived from the mains via a suitable circuit or from a battery or from somewhere else. The point of the 12 volts DC is that the transistor switch is designed to work on 12 volts DC and use a low voltage transistor. Transistors capable of operating directly at mains voltages are relatively few and far between and much more expensive. |
| May17-12, 07:48 AM | #25 |
Recognitions:
FOIWATER, this needs a bit of polish: "The diode is to dissipate the current that flows..."
| May17-12, 07:52 AM | #26 |
Recognitions:
| May17-12, 07:53 AM | #27 |
Provide a discharge path for
| May19-12, 03:24 AM | #28 |
So let me see if I understand how this circuit works..
When button P1 is off no current flows through the circuit, and as long as the switch parallel to the transformer is off no current flows through the lamp. When P1 is pressed and the switch closes, current begins to charge the capacitor. Once the capacitor charges to 7.3 V the transistor turns on (-> according to the description) then the 220 AC voltage along with the 12 volts provide the voltage to light up the lamp. P2 short-circuits the transformer circuit unit. Did I get it right? |
| May19-12, 04:45 AM | #29 |
Recognitions:
Mostly OK except that there is no transformer in this circuit.
The thing with an inductor in the dotted box is a relay. When current flows through the inductor, it attracts a piece of soft iron attached to a switch, turning the switch on. When the switch is on, it allows current to flow through the lamp from the 220 volt mains supply. The reason a relay is used is to allow a circuit using only 12 volts to control a much more dangerous 220 volt AC supply. Also, most transistors will work on 12 volts so the choice of transistors for this circuit are easier than if it had to run on 220 volts AC (if it was rectified and filtered). This circuit's main function seems to be to produce a slight delay after pushing switch P1 before the lamp comes on. |
| May19-12, 07:19 AM | #30 |
Recognitions:
Switches labelled Pn are probably push-buttons that connect only while held down, then when released the contacts open by spring operation. So the lamp stays on while you keep your finger on P1. But if you release the pressure on P1 then no further current can flow via R1 into the transistor base. |
| May19-12, 12:18 PM | #31 |
I work in industrial electrical and electronic machine manufacturing. we use these alot; we call them flyb, ack diodes. Flyback is when the current through a coil is interrupted and all the energy stored in the coils of the solenoid is near-instantaneously delivered into the circuit literally as the switch is opened, in the form of an arc across the contacts of the switch that is opening. the flyback can be more than a dozen times the voltage of the one that was applied to the coil. when it is a switch in the primary of a transformer opening, the flyback on the secondary side is amplified bigtime; we call those a flyback generator, like an ignition coil in a car.
the diode in the drawing (shorting out a flyback generator) is going to give the flyback current a safe path to dissipate through, instead of blasting its way through the circuit. since the flyback is in the same direction as the applied voltage was, it will circulate through the diode until it is gone. J |
| May23-12, 11:52 PM | #32 |
| May24-12, 02:35 AM | #33 |
Recognitions:
If you just wanted to turn a lamp on and off, you would get a 250 volt switch and switch it on and off. Of course.
But if you wanted a delay after pressing the switches, as in this case, or if you wanted to turn the lamp on and off using a computer or a low voltage electronic circuit, then you would need a relay driver circuit like this. |
| May24-12, 04:14 AM | #34 |
So basically the other circuit is just to allow for delay and computer control. But once the lamp turns on, the voltage stays at 220 V. Yes? |
| New Reply |
| Thread Tools | |
Similar Threads for: How can a diode defend the coil during transistor cutoff?
| How to bias a transistor into cutoff | Electrical Engineering | 2 | ||
| npn transistor with a diode | Introductory Physics Homework | 10 | ||
| diode to protect transistor | Electrical Engineering | 5 | ||
| Transistor as a zener diode | Electrical Engineering | 1 | ||
| Different between NPN transistor and diode? | Introductory Physics Homework | 0 | ||
