Some special consequences from the limits of e: need a little help
  • Thread starter Thread starter maxpayne_lhp
    Limits
The discussion revolves around limits involving exponential functions and logarithms, specifically focusing on the behavior of functions as they approach certain values. The original poster shares their attempts at calculating various limits, including those involving the expressions (1+2/x)^x, (1+3x)^(1/x), and ln(1+sinx)/x.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of substitutions and approximations to evaluate limits. The original poster questions their approach to the limit involving ln(1+sinx)/x and seeks suggestions for alternative methods. Others suggest using L'Hôpital's rule and approximations for small values of x.
The discussion is active, with participants providing various insights and suggestions. Some participants have offered guidance on using approximations and have pointed out potential misunderstandings in the original poster's reasoning. There is a mix of interpretations and methods being explored without a clear consensus on the final approach.
Some participants mention the lack of familiarity with certain mathematical concepts, such as derivatives and L'Hôpital's rule, which may impact their ability to solve the problem effectively. Additionally, there are references to the need for justifying approximations used in the calculations.
maxpayne_lhp
Well, hello!
I have difficuties solving a problem.
Well, the first 3 ones are done successfully:
a. Calculate out the lim (x -> inf) of (1+2/x)^x
But assuming that 2/x = 2/t, I got the result to be e^2
b. Do the same thing with the lim (x ->0) of (1+3x)^(1/x)
Well, yeah "do the same thing", I assumed that t = 3x; I got the result of e^3
c.lim (x->0) of [(e^3x)-1]/x . Well, t = 3x this time. I got it as 3
But the third: d
lim (x->0) of { ln(1+sinx)/x }
Well, I tried assuming that t = sinx , but I got stuck in solving this, so far. Please give me a suggestion! Thanks!
Did u study derivatives and L'Hôspital's law??
Daniel.
P.S.The first 3 are perfect.
There are 2 approximations which u can use:
For "x" very,very small
[tex]\sin x\sim x[/tex]
[tex]e^{x}\sim 1+x[/tex]
Use these 2 approximations for good purpose...
Daniel.
No I haven't learned about it yet. Any other way?
Use the approximations.The first one can be proven via intuitive geometrical resoning and the second,well,it's a bit difficult...
Daniel.
P.S.The final result is "+1".
maxpayne_lhp said:
Well, hello!
Changing x to t (as in 2/x= 2/t) doesn't do anything! If you have learned that lim(t->infinity) (1+ 1/t)t= 2 then what you can do is let t= x/2. I'll bet that's what you actually did. Of course, then x= 2t and, clearly, as x-> inf, t-> inf. The limit becomes
lim(t->inf) (1+1/t)2t= lim(t->inf) ((1+ 1/t)[sup t[/sup])2 which, since x2 is continuous, (is lim(t->inf) (1+1/t)t)2= e2.
I assume that "(1+3x)" was really (1+ 3/x). If so, yes, that's correct.
Is that e2x or e3x? I assume the latter. Taking t= 3x, x= t/3 so this become lim(t->0)3(et-1)/t. (et-1)/t goes to 1 because it is the derivative of ex at x= 0?
But the third: d
How about using the fact that ln(1+ sin x)/x= ln{(1+ sin x)1/x}. Does that help? If we let y= ln{(1+sinx)1/x}, then
ey= (1+ sin x)1/x. Can you find the limit of that?
Ok, I got it! I was so stupid!
Thanks, Mr. Hallsofivy, thanks Mr. Dextercoby
Sorry, misters, but I got stuck while finding the lim of e^y.
Halls said that
[tex]\lim_{x\rigtarrow 0} \frac{1}{x}\ln(1+\sin x)=\lim_{x\rightarrow 0} [\ln(1+\sin x)]^{\frac{1}{x}}[/tex]
Denote the limit by "L" and exponentiate the previous relation.That's what Halls said.
[tex]e^{L}=\lim_{x\rightarrow 0}(1+\sin x)^{\frac{1}{x}}[/tex]
And now use the trick:
[tex]\lim_{x\rightarrow 0} (1+x)^{\frac{1}{x}}=\lim_{\frac{1}{x}\rightarrow +\infty}(1+\frac{1}{\frac{1}{x}})^{\frac{1}{x}}=e[/tex]
and the fact that
[tex]\lim_{x\rightarrow 0}\frac{\sin x}{x}=1[/tex]
to find your answer.
Daniel.
Why [tex]e^{L}=\lim_{x\rightarrow 0}(1+\sin x)^{\frac{1}{x}}[/tex] ?
Well,since:
[tex]L=\lim_{x\rightarrow 0} \ln(1+\sin x)^{\frac{1}{x}}[/tex]
,what do you get by exponentiating the equation?
Daniel.
Well, I got it as lim (x->0) of [(1+sinx)^(1/x)]
Okay now use the trick with the reversing fractions and the of sine ratio.
Daniel.
Okay, thanks!
PS: Thanks for telling me about LaTex! It's cool! I'm learning it!
Hmmm... So far, I've done it. But I think tis way is better:
[tex]\lim_{x\rightarrow0} \frac{ln(1+sinx)}{x}[/tex]
=[tex]\lim_{x\rightarrow0} \frac{ln(1+sinx)}{sinx} . \frac{sinx}{x}[/tex]
=[tex]1.1 = 1[/tex]
Is it right?
Nope.Can u prove that the first limit is "+1"??I frankly doubt it.
BTW,[tex]\sin x[/tex]
The functions should not be italic...
Daniel.
If you have two functions which are both tending to zero as x tends to zero then they can be both replaced by equivalent infinitesimals. The approximation, [itex]\sin x = x[/itex] near zero, would be useful here (though not without justification) if you do not know that [itex]\frac{ln(1+x)}{x}[/itex] tends to 1 as x tends to zero or you are precluded from using the first form L'Hopital's Theorem.
Uhmm... alright!
Just imagine that [tex]sinx = \alpha[/tex]
Then the thing above is equal to:
[tex]\lim_{x\rightarrow0}\frac{ln(1+\alpha)}{\alpha}[/tex] (*)
Then, this limit is a consequence limit of e:
[tex]\lim_{x\rightarrow\infty}(1+\frac{1}{x})^x = e[/tex]
So. (*) =1
Hmm... yeah, the basic consequence
[tex]\lim_{x\rightarrow0}\frac{ln(1+u)}{u}=1[/tex]
  • · Replies 19 ·
  • · Replies 20 ·
